Question about Intex 2,500 gph Above Ground Pool Replacement Filter Pump only
Pump stopped working
I have the Intex 603 filter pump for my 10 by 30" above ground pool. Recently, we have had a lot of rain and lightning. I disconnected the pump and placed it on the concrete floor. It apparently became waterlogged in all that rain. I let it dry out and shook out as much water as possible. Now it will not work. I cannot find a way to replace the plug. Do I have to replace the whole pump? If so, can I upgrade to the 108R pump?
  • 13 Answers
SOURCE: I have a 24 x 52 intex above ground swimming pool
You must open the little valve on top to let out the air, then screw it back on when water reaches the top,  and ensure both gates are open.
Posted on Mar 30, 2009
  • 77 Answers
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Posted on Apr 28, 2009
  • 670 Answers
SOURCE: I need instrucions for how to set up a model 108r intex pool pump
Best I could find. Includes drawings. Good luck. http://www.inyopools.com/guide_new_above_ground_pool.aspx
Posted on Jun 22, 2009
MOTORWIZJ
  • 1338 Answers
SOURCE: how do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
ck9632147
  • 3 Answers
SOURCE: intex above ground pool 15x48 filter pump problems
Get the air out of the filter housing
Posted on Aug 19, 2010
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
Intex saltwater system. We had a lot of rain & now the pool is green. What should we do?
Shock the pool is easiest at this point. Or you can turn the system all the way up and wait. All the rain probably just dropped you residual way down and now it's trying to fight it's way up again.
Sep 26, 2010 | Intex Automatic Salt Water System for ...
Ph level too high in my Intex Saltwater System Pool. How long do I hold the 3-way test strip in the water before reading? I have added the proper amount of ph lower 3 times and it is still high. I hold it...
Have you had a lot of rain?
Rain will make ph go up
too much chlorine can produse Hi ph
Just keep treating with ph down ti'll you reach 7.2-7.8
As for the test strips you only need to dip and pull out
then wait 10 seconds and compare
Jul 17, 2010 | Intex Automatic Salt Water System for ...
How do you prime the pump for intex ubove ground
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only: how to converte to larger filter...
You can simply buy a larger pool filter that is designed for pools in your size range. Look for one that is designed for smaller above ground pools. You can find lots of different pool filters at backyardcitypools.com.
May 17, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 2,500 gph Above Ground Pool Replacement Filter Pump only Logo
391 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
