Question about RCA Thomson Digital Cable Modem (DCM305R)
Password for Thomson speed touch 576
I forget the password for my router, and its not connecting now how can i reset it again or get my password
  • 85 Answers
Look for a reset hole or button usually located in the back or under the device and hold for 15sec
Posted on May 24, 2009
I have a thomson twg850 router but it won't accept my password, what do i do
Hello you might have to reset it and set it up again.
TWG850-4U Default IP: 192.168.0.1
TWG850-4U Default Password: admin
TWG850-4U Default Username:blank
Here is a guide:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Good luck
Nov 19, 2012 | Computers & Internet
I have a thomson b94560 wi fi router and cant find the password for it to connect my kindle.
You may need to reset your router. Most routers will have a default username and password printed somewhere on the router itself. Once you find it find the reset button, usually a small whole with a recessed button inside. Use a pen or something small enough to reach the button and hold it down while the routers still on for at least 15 seconds. After which you will just need to reconfigure your router to the setting you had before. And don't forget to change your default admin password because the default passwords are usually readily available on the internet.
Mar 01, 2011 | Computers & Internet
Cant change MTU value on 3com officeconnect router
no, the MTU is being overridden by the cable provider. Most ISPs use 576 as the default MTU as this was shown to be the most effective packet size some years ago; unfortunately, that was before streaming video and large downloads, but some ISPs haven't changed their policies. The effect on your speed will only be noticeable if you are downloading large files, streaming or using skype or a similiar VOIP product. To be honest, most of the core switches on the internet use 576 anyway, so changing locally really won't matter.
Feb 23, 2010 | 3Com OfficeConnect Router
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
Lost connection
what u need to do is go to the interface of ur thomson speed touch through writing the ip address of that modem on the address bar of ur internet browser then go in that setup....Choose router instead of bridge.
Jul 14, 2009 | Computers & Internet
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Speedtouch 576
Have you tried to reset the device using a pin or paperclip, this should restore the device to factory settings and allow your new internet service provider help you with the setup to connect to thier service.
May 12, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson Digital Cable Modem (DCM305R) Logo
531 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
