Question about LG Electronic Window Air Conditioner
LG 10,000 btu air conditioner
I can set it at 60 and it wont get any colder than 67 in the room, the compressor shuts off with fan still blowing on high. it will go up to 68-69 before the compressor kicks back on. I would like it to get 60 in the room is there anyway I can mod or adjust something?
  • 93sleeper May 28, 2009
    I did the same thing and I guy that came out to look at it said that its working fine
Let me knkow what he says i have the same problem
Posted on Jun 29, 2009
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
Posted on May 28, 2009
My 18,000 BTU LG window AC: The compressor wont shut off.
replace the thermostat
of course it will not stop if the air in the room is not controlled ( doors open , window open, room to big fore the ac unit or if the temp control is set too low ( 25 c is optimum setting)
Aug 10, 2016 | LG Heating & Cooling
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
How do I get my LG 12000 BTU ac/dehumidifier to dehumidify
This is a quote from the manufacturer.
Dry mode is used to remove humidity from the room
without additional cooling. Once the set temperature
is reached, the compressor and circulation fan turns
off and only the exhaust fan will run. Fan speed is
pre-set and cannot be adjusted.
Apr 24, 2011 | LG LP1200DXR Portable Air Conditioner
Room temp stays at 76 and will not get any colder even though unit seems to operate and compressor sounds like it turns on and fan blows and water drains . it is set to 60. room is about 300 sq ft
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
May 06, 2010 | Maytag M6P09S2ACOM Air Conditioner
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
The 10,000 BTU portable room a/c unit is not running cold enough
Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
Try those things if that doesnt work then you need a service call.
Jul 10, 2009 | Whirlpool ACP102PR Portable Air...
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
LG Electronic Window Air Conditioner Logo
310 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
