Question about Kodak EasyShare C743 Digital Camera
No good pictures
Whenever i take a picture inside a room there is a yellow or red hand on top telling me the picture is garbage, please tell me how to fix it
    Problem Solver:
  • 13 Answers
The symbols you are seeing are the blur warning indicators.
The yellow hand warns you that the picture may not be quite sharp enough for a standard 6" x 4" print - however you may be happy with it.
The red hand warns you that the picture is most likely to be poor quality, and won't produce a good 6" x 4" printed photo.
The reason you're getting these indoors, is that there's not enough light for the camera to take a good picture. As it tries to do so, it opens the shutter for longer to let more light in - however on doing so, if the camera isn't absolutely still, then the warning symbols will come on.
To remedy the above I'd have the following suggestion - if possible and practical, when shooting indoors, try and rest the camera on something solid when taking a photo. If this is not possible - try leaning against a wall to stabilise yourself. Even though you think you are holding the camera still - it's moving quite a lot.
Try one hand held photo - and one photo with the camera resting on something solid like a table and see what the difference is.
Posted on Jun 02, 2009
Have 47" Samsung HCL743W rear
Here is what to do to confirm what problem is, go to black and white program and make sure color adjustment is turned all the way down to zero.
What you are looking for is what color is the screen?
If it a primary a yellow looking screen (all or most) you have bad Glycol in most likely the blue tube. These sets have a sealed area with a sealed area with Glycol (it is like antifreeze and meant to keep the face of the the three picture tubes cool).
What can happen (usually the blue) is it becomes contaminated with bacteria====note, if blue tube is contaminated you will have yellow screen (red and green=yellow.0
The real easy way to confirm if this is the case is with the back removed and access to the three large lens on top of the tubes look into each lens, if the blue one has no picture and looks like a floodlight, but the red and green have a picture, YOU HAVE FOUND OUT YOUR PROBLEM.
I can tell you if this is the case I can tell you what is involved, this most likely is not a do it yourself repair but i can tell you what is needed.
SD TECH
Dec 28, 2010 | Samsung HCL473W 47" Rear Projection...
MY BACK UP LITES DON'T WORK. I CHECKED THE FUSES UNDER THE HOOD, & THEY ALL LOOK OK. I CAN'T SEE THE FUSES INSIDE CAR ON THE KICK PANLES. CAN YOU TELL ME WHAT LOCATION THE FUSE MAY BE THAT IS FOR...
your back up lights run on the gage fuse. the problem is probably with the switch on top of the transmission. The switch looks like the picture below and has 2 cables coming out. Remove the connectors from the switch. Grab the one that only has 3 terminals inside and connect the terminals inside the connector that go to the red and yellow wires using a big paper clip. Turn the ignition key on to see if the lights work. If yes, replace the switch. If not, problem is in the wiring. Please let me know if you have questions.
Nov 08, 2010 | 1987 Toyota Cressida
Have a hurtz neverlost portable & inside the power unit there is a componant thats desoldered its self A514 GEV its a small black 7x5mm part fitted inline to the power socket can you tell me if this...
please do not rate this yet, this is not a solution, but i cant post a picture using the clarification option.
look at the picture below and tell me if your board looks like this and where the part is your referring to...the power port is to the top right of picture ....if you have a 4040, it will be yellow if its the original port..the replacement is a black one...possibly the part your referring to is right behind and to the top of that power port.
bill
Jun 20, 2010 | GPS
When taking pictures of face in room lights , particularly in nig
taking photos inside a room causes dark pictures with red eye
Dec 30, 2009 | Nikon Cameras
My camera not focusing
Dear juanvillar46 I found this important information to explaing better about the hand color and meannings
Understanding blur warning icons If the feature is turned on (see ), a picture blur warning icon autourg00531002id1716777.jpg is displayed during quickview and review.
spacer.gif Green - Picture is sharp enough for an acceptable 4 x 6-inch (10 x 15 cm) print.
Yellow - Picture may be sharp enough for an acceptable 4 x 6-inch print or sharpness is not determined.
Red - Picture is not sharp enough for an acceptable 4 x 6-inch print.
White - Printability is still being determined.
Your Rating is very important for me
"Was this helpful?"
Mar 30, 2009 | Kodak EasyShare C643 Digital Camera
1998 Sears 626.5538 Television color issues???
You either have one of two problems the first is bad picture tubes or circuitry to drive them, At this age it time to get a new TV; Both repairs are not cost effient.
Dec 18, 2008 | Televison & Video
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
Kodak EasyShare C743 Digital Camera Logo
109 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
