Question about Audiovox FR2302 2-Way Radio
Blinking E on the screen when I turn it on.
I have a audiovox fr230-2 walkie talke. When I turn them on one has a blinking E on the screen and I can not get them to comunicate.
Syncernise audiovox walkie talkies
I assume you mean Synchronise audiovox. By that, I assume you have two of more radios that don't talk to each other. If you can provide a model number, I can guide you to a manual website.
Jul 22, 2016 | Audiovox Radio Communications
Audiovox GPRS 2way radio manual?
You can download it from here: http://www.manualslib.com/manual/12720/Audiovox-Gmrs602pk.html
Feb 17, 2015 | Audiovox GMRS-602PK 2-Way Radio Walkie...
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
We have three Uniden walkie talkies - two of them have a symbol of a walkie talkie above the channel - these two will not talk to each other - but they talk to the one without the symbol - how do I ge
Sounds like the PL tone is set on the two, with different tones. Go to the menu, find the tone screen, and turn off the tone (or set them all to the same tone). That should fix the problem!
Oct 03, 2014 | Uniden Radio Communications
Audiovox GMRS1072CH MANUAL
You can download the manual from here: http://www.manualslib.com/manual/355091/Audiovox-Gmrs1072ch.html
Jul 10, 2014 | Audiovox 2-Way 14 channel FRS Family Radio...
How do i make my audiovox walkie talkie stop making a beep noise
In the "settings" there should be an option to turn off "beeps" or "tones" or "notifications", something to that effect.
Feb 16, 2014 | Radio Communications
Where can I get the belt clips that go on the back of my Audiovox FR-1438 Walkie Talkies ??
I'm not familiar with that make of radio, but try taking the unit to your local Radioshack or similar store, and I'm sure they will come up with a solution.
I hope this answer helps you find the part.
Cheers,
Peter
Feb 04, 2013 | Audiovox Fr-1438 Two Way Walkie Talkies...
Sqeal when talk button is pushed
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
Apr 21, 2009 | Audiovox 2-Way 14 channel FRS Family Radio...
Need Frequency List
CHANNEL FREQUENCY 01 462.5625 02 462.5875 03 462.6125 04 462.6375 05 462.6625 06 462.6875 07 462.7125 08 467.5625 09 467.5875 10 467.6125 11 467.6375 12 467.6625 13 467.6875 14 467.7125
Dec 14, 2007 | Audiovox 2-Way 14 channel FRS Family Radio...
Audiovox FR2302 2-Way Radio Logo
44 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
