Question about Samsung Televison & Video
Please help - I have a Samsung HT-TZ212 Home Cinema, but I cant play any discs - all I get is the following message - Can't Play Disc,Please Check Region Code Error.
  • 5 more comments
  • chrisharriot May 24, 2009
    Sorry, but the solution does not apply, as the DVD Player will not play ANY discs from ANY region. Any other ideas?
    Thanks
    Chris
    Sorry - should have mentioned - have also tried that solution - still does not work.
    Thanks
    Chris
    I have already tried the 84269 region code hack, which has not sorted it out, any help please. Thanks
    Sorry - (maybe me being thick) but what do you mean pulse on remote?
    Hi, when I put in the 0000 the region edit does not appear for me to set the region to 0 and finish the instructions you gave.
    Thanks
    Chris
    Hi, I have tried that and it does not work. Any other suggestions?
    Thanks
    Chris
  • chrisharriot May 25, 2009
    The default solution did the trick. Thanks.
  • 230 Answers
Id try these two:
Sounds like you have alread completed this but I'll post it anyway just in case my procedure differs.
To change the region on this player
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control and enter dvd-mode
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
Try and default your dvd back to factory settings:
While the player is in No DIsc mode, hold the DVD Players STOP button for longer than
5 seconds. INITIAL appears on the display and all settings will return to the default values.
Press the POWER button.
Using the RESET function will erase all stored settings.
If the above two fail, unfortunatly the unit may have to go in for service.
Posted on May 25, 2009
  • 854 Answers
Posted on May 24, 2009
    President:
  • 2,004 Answers
It is always an issue with dvd players that are regionally based.
Please consult the dealer or a samsung service centre near you.
  • 1 more comment
  • Onifade Adewunmi
    Onifade Adewunmi May 24, 2009
    Okay.
    Visit http://www.videohelp.com/dvdhacks/samsun...
    This should solve i. rate this fixya.
    murphybanton
  • Onifade Adewunmi
    Rate this.
  • Onifade Adewunmi
    Try this.................
    Switch on dvd without disc and let it load till it shows no disc.
    Open
    tray and using a remote control enter four zeros.
    Region edit will
    appear and press zero and press enter and then pulse on remote.
    Switch
    off dvd and on again.
    Dvd is region free.
    Rate after success.
    Murphybanton
Samsung home cinema ht-330 dvds wont play no disc displayed
The most common reason is either a dirty or bad Optical Pickup unit in the player which is what reads the disc, and you will get no disc, cannot read disc etc.
Dec 20, 2012 | Samsung Audio Players & Recorders
When trying to play disc get message disc not recognised
It would be helpful if you had stated the type of disc you will be trying to load.there are several formats that can be used when writing a disc,thats why its important to check the types of disc formats your player can play before purchasing a player...otherwise you are trying to load a disc with a format that your player dosent support
Dec 09, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Want to make samsung ht-x20 home cinema multi regional. when entering code 84269 and enter the player then shuts down. Still not playing DVD. It still asks "check regional code". Ernst
hi there! turn on the hometheater then wait for the no disc display, press the stop botton, do not release until the unit turn off, you will see the initial word on the panel,then try to play your disc
Apr 08, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
I have a sumsung dvd home cinema system ht.thx25 when I put a dvd in it says disc unknown but when I put a free dvd in from the newspaper it plays.
Is the disc just a regular disc, not HD or blu ray?
Is the disc a region 1 coded disc?
If it is, the unit should play it fine.
Jul 01, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Disc Unknown keeps coming up on the screen
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
Mar 30, 2009 | Samsung HT-DM550 System
No Disc display
wrong reganal code most likely there are sites were you can unlock your dvd player (hack it) so it will play disks from anyware
Feb 17, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | Televison & Video
Televison & Video Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
