Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
Amana BR22 top refrig not cooling
How do I fix a return air problem with Amana BR22? Cold air comes into top compartment when both doors are held open but stops when bottom freezer door is closed.
  • 6,784 Answers
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
Posted on May 24, 2009
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
1992 T&B refrig drips water from inside top of refrig compartment Is it a blocked drain tube? Or bad heater evaporator unit?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator compartment is not cooling. No air
your air deflector isn't opening up between freezer and refrige to let cold air down
Nov 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Water on top of freezer door and rubber inside is getting moldy fridge temp is 43 and freezer products are fine amana BR22* bottom out freezer/refrigerator
The seal is broken around the door and this requires total replacement to prevent the moisture, the cold air from escaping, the warm moist air from entering and causing your refrigerator to run more often than needed and running up your power bill. If I had your model number it would help me to help you find a door seal and fix the problem. So if you need my help you will need to locate the make and model number and write me a message here on Fixya that lets me know you have the number and are ready for help. There are 28 different versions of the BR22 so click HERE and then enter the complete model number. Thank you and if I can help you please let me know, If all else fails contact me at appliancepartsse@yahoo.com Thanks, Sea Breeze
Aug 06, 2009 | Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
526 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
