Question about Nintendo DS Lite Console
Still not charging
Does not power up or turn on. posted by AtticusDS on Oct 18, 2007 Report abuse
DS Lite is only 2 months old and today it stopped working.  Green power light only stays on for a second when turned on - and only when it is plugged in. When you plug it in, the red charging light stays on for a second then goes out. When it is NOT plugged in, no lights come on, even when you turn it on.  It was not dropped or damaged. It worked last night but this morning it does not. Thanks, Janet
Comment by AtticusDS, posted on Oct 20, 2007
I tried to charge it with the car adaptor - the red light just goes on for a second then shuts off, just like it does with the house charger.  How can I check to see if the battery will not accept a charge? I took it out and cleaned it like the first suggestion I was given.  Still not working.
Still need a solution for this problem?
Try our Premium Assistance plan Best Solution posted on Oct 20, 2007
By  Embem
Rank: Not rated
Rating: 53.33%, 3 votes
it could be the power cord that is the problem, see if you can go to a shop or if you have a friend with one, see if you can borrow their cord to see if it works hope you find a sulution :)
  • AtticusDS Oct 20, 2007
    okay - I guess I'll do that. I appreciate your help even though it didn't get fixed. Thanks, Janet
Called 1-800-255-3700 - they told me where the nearest repair center is. As long as the Nintendo DS is less than 1 year old - it is completely covered under the warranty. THEY FIXED IT for free.  If they could not fix it within 45 minutes, they would have given me a refurbished one - which would have had a 1 year warranty on it.  I wish I knew all this before spending $9.95 for this service.
Posted on Oct 25, 2007
Sounds like mainboard fault need to be replaced if still munder warrenty take back to shop to get fixed
Posted on Oct 24, 2007
    Problem Solver:
  • 3 Answers
I'm not sure that you can actually check if the battery does not accept charge, you might want to ring the distributer and see if they can send you a replacement battery :)
Posted on Oct 20, 2007
Nintedo Ds Wont turn on! Even if Charged!
Does the yellow light come on when charging? Could be that the fuse for the charging circuit has gone, or on of the screens has been damaged. If it's only 4 months old and not been dropped etc, send it back to Nintendo I'd have thought.
May 24, 2010 | Nintendo DS Lite Console
DS won't turn on
Hi Atticus,
I have seen this happen when someone plugs the wrong charging cord up to the DS lite, Is there any chance some one did this to your DS lite.It sounds also as if the battery is not making proper connection.
  1. REmove the battery from the compartment
  2. inspect the connector on the battery and where the battery connects to the DSlite.
  3. Wipe thee connections off some way. I suggest some contact cleaner for bith the battery and Battery compartment connections
  4. Try the DS lite again with the battery installed.
I hope this gets you in business  Atticus. Do not Vote until we get it working.  Try this and add a comment to this problem posting. I will answer as soon as I possibly can. Thank you very much for the opportunity to solve your porblem with a DS Lite.
Oct 18, 2007 | Nintendo DS Lite Console
Nintendo DS Lite will not turn on.
There may be a problem with the battery itself. The same thing happened to my sister's DS. You could take it to a repair shop, and for about $70 - $90 they will fix it. That in my opinion is better than
buying a new one for about $200.
Hope it helps~
Jan 11, 2009 | Nintendo DS Lite Console
After charging, I try to turn it on and it flashes and turns off
wen u 1st got ur ds lite...u should of at least charged it for 5 hours and if u didnt u might need 2 by a new battery...
Dec 09, 2008 | Nintendo DS Lite Console
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
Nds lite doesnt power off
Dear Cornjo,
Your situation has baffled me completly. Here are some solutions that might help you:
  • How old is your DS/DS Lite? If it is less than 1 year old or if you have a gurantee for more than 1 year, you can take it back to the shop.
  • Try taking out the battery and not putting it back for at least 24 hours
  • Charge your DS COMPLETLY and do not use it for a while
From Andrei S.
Aug 17, 2008 | Nintendo DS Console
Nintendo ds lite - 2 months old
did you drop it a lot? If you did you may not be able to fix it...
Dec 26, 2007 | Nintendo DS Lite Console
First Attempt to fix didn't work
that happened to me , i had to get a new one or i could wait about 2 mouthes 4 nintendo to put it up ,fix it, and send it back , so i got a new one , but go to nintendo.com or google it
Oct 19, 2007 | Nintendo DS Lite Console
I think that this problem is caused by either f1 or f2 fuses being blown. The other problem mentioned where the green light comes on for a second then goes out again is usually caused by the cable connecting the top screen to the motherboard, it is either broken, damaged or incorrectly seated.
Nintendo DS Lite Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
