Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 55P8288A Picture is cloudy
I don't have the manual or remote.
  • Philips Master
  • 3,866 Answers
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
Posted on May 24, 2009
    Problem Solver:
  • 5 Answers
Magnavox 55P8288A go to magnavox.com, Support and search 55P828899 and the owners manual and a Quick start setup is there.
Posted on Jun 20, 2010
Model number#55P8288A Phillips Magnavox(PVT910)We have no owners manual.And the picture is too orange.where can we get a manual to set it right
http://www.tvrepairkits.com/download-guides/tv-kit-001-002.pdf
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
Service & Repair manuals for your unit.
Sounds like your set has developed a "Color Mixing" problem, Please use the troubleshooting procedures and you will soon be able to find out what to do.
Apr 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 22, 2009 | Televison & Video
No picture, no sound
sounds like the main board maybe going out or is gone and the lamp may have went as well
Jul 20, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need owners manual for Magnavox 55" Projection TV 55P8288A, pleas
This manual does not seem to be available anywhere. I looked for it on the Magnavox website http://www.magnavox.com and it was not available. You can call the magnavox customer support at this telephone number. 1-800-705-2000. Give them the model number of you television and ask them for their help getting a copy of the owners manual. I also check for it on a google search. The search turn up no source either. So you best bet is to try and find another person who has the same model television and ask them to make a copy for you. You can do this on this website by looking up the people who have asked for help with the same model television and leaving them a message that you need a copy of the owners manual.You can also go to other help websites and ask for their help in getting a copy of the owners manual. I hope this information helps you with your problem
Jun 02, 2009 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No Picture
I had the same exact problem pulled the chassis ohmed the convergance ics though one read different than the other replaced both put chassis back in set fired right up.Hope this solves your problem!
Feb 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 55
Sounds to me like you need a new control panel board which should run you about $150-$200 max! might be semi burnt out like mine was and that is what i had to pay not sure if this helps but hey ya never know :)
Sep 08, 2008 | Philips Magnavox 55P9271 55" Rear...
Magnavox 55
It could possibly be the sensor or the front keyboard panel itself, most front keyboard panel circuit board have the Remote sensor on them
Sep 08, 2008 | Televison & Video
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
463 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
