Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
OVEN FLAME TOO HIGH
I AM TRYING TO ADJUST OVEN BURNER FLAME.dO I TURN THE ADJUSTMENT NUT CLOCKWISE OR COUNTERCLOCKWISE
TO GET A BLUE FLAME. RITE NOW IT IS ORANGE.
MY E-MAIL IS NUTTYPROFESSOR10@AOL.COM
THANKS
JOHN
    President:
  • 1,136 Answers
HI, To adjust the size of the flame, turn the orfice clockwise to make it smaller. you can also try and adjust the air shuttle on the burner.
Are you trying to change from natural to LP?
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 25, 2009
Whirlpool model SF3020EKQ3 was converted to LP oven lights nice blue flame but flame is very small oven does not get hot enough
HI,
If your able to adjust the orifice hood to the oven, then turn it counterclockwise unit the burner is full and minimal yellow flickering is present. If you go too much, this can be deadly can cause carbon monoxide to admit into the kitchen during use. I have found adjusting while the burner is on is the easiest way to make sure it is correct, use caution....
I hope this helps
Jul 23, 2011 | Microwave Ovens
Need to adjust the burners the flames to high
Hello there:
Please follow these very easy steps and this should help you
Instructions Things You'll Need:
  • Gas Ranges
  • Screwdriver Sets
  1. Step 1 Find the tube that feeds the burner. There's a burner air adjustment on it that mixes the air and gas.
  2. Step 2 Look to see what type of burner air adjustment you have: It will either be a barrel-shaped chamber or triangle-shaped with a cover plate.
  3. Step 3 Loosen the air-shutter screw on the barrel-shaped type. This screw is on the end of the barrel closest to the burner.
  4. Step 4 Open the shutter on the barrel-shaped type by turning it counterclockwise; close it by turning it clockwise. Opening it will add more air, which will make the flame higher; closing it will reduce the air in the mix and lower the flame.
  5. Step 5 Loosen the screw holding the plate on the triangle-shaped burner air adjustment. Don't remove the screw - it just needs to be loose enough to move the plate.
  6. Step 6 Move the plate so that the opening is either more open or more closed. More open will make the flame higher whereas more closed will lower the flame.
  7. Hope this is very helpful for you
  8. Best regards Michael
Feb 02, 2010 | Kitchen Ranges
Flame to high
Hi, To lower the size of the flame, turn the orfice on top of the gas valve in the oven. You will need a 1/2" wrench and need to turn the orfice clockwise to lower the flame.
please let me know if this helps or if I can assist you further.
Vic
Jul 04, 2009 | Kitchen Ranges
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Dec 22, 2006 | Kenmore 78673 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
1,124 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
