Question about Daewoo DTS42 42 in. HD-Ready Plasma Television
Heard a pop and the picture went blank
Turned the television ( a daewoo 42 inch) on and heard a pop. The picture went blank immediately. What is wrong and is it fixable?
  • 62 Answers
    Master:
  • Daewoo Master
  • 505 Answers
I had this problem before on my LG TV. My solution is to put a 12V fan on the tuner board processor. The problem is caused by the TV overheating and when the tuner CPU overheats it sends a high temperature OFF command that instructs the power board to shut the tuner board off (although the rest of the TV stays on). This is why it sounds like a click when it happens. You cannot likely get a TV repair man to fix this because the LG TV's do not have adequate heat control other than vent holes on the bottom and top. This is a design flaw that started a class-action lawsuit against LG.
Posted on Dec 13, 2014
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
I have 42 inch plazma no picture
Ur backlight video inverter board is dead.Buy parts like capacitors for replacement with soldering or buy the whole board.Tries these websites.Shopjimmy.com,Partstore.com or Ebay.com.
Sep 29, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
The picture went blank on my 42 inch Olevia lcd tv
What happened and can it be repaired for less than the cost of a new tv?
Anyone would be hard-pressed to give you a definitive answer to that question but if, as it very well could be, the main power supply has failed, you may be able to buy and replace this yourself and I would guesstimate the cost at under $150 US for a new board.
Disturbing part is the chance that the supply was damaged by another problem downstream from it. Most modern supplies can protect themselves from and overload so I think the supply was at fault rather than being a victim.
Nov 25, 2008 | Olevia LT42HVi 42 in. LCD Television
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PX4DV 42" problem
Aug 15, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Daewoo DTS42 42 in. HD-Ready Plasma Television Logo
388 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
