Question about HP Photosmart 2610 All-In-One InkJet Printer
Says to remove and check color ink cartridge
It say to remove and check color cartridge. i did so but see no problems. it still wont work.
    Problem Solver:
  • 4 Answers
Take out cartridge and clean the contacts. On the printer and on the cartridge. Mine did that and there was a speck of ink where the cartridge meets the printer contact. Actually, it was a defective cartridge.
Posted on May 24, 2009
My MFC-430W wont recognize color ink cartridges
Faulty Sensors or Cartridges if they are compatible
Sep 14, 2014 | Brother MFC Office Equipment & Supplies
Xerox phaser 8500
Did you install the cartridge correctly? Sometimes (and it does happen frequently), is that when installing a cartridge, often you forget to remove the plastic strip that separates the toner from the inner drum, check for that.
Dec 30, 2013 | Office Equipment & Supplies
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
New color ink cartidge won't work
Did you remove the tape on the bottom of the cartridge before you installed it?
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Not printing
Have you checked if your cartridge protective tape is removed. There is this transparent tape in your ink cartridge contact area especially for HP printers, you need to remove it so you can print.
It would be helpful if you put in the actual unit with your question...
Mar 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Color
I am assuming from your brief problem description that you are getting bad colors when you changed your color cartridge. Are you using a new and certified HP ink cartridge? Are you doing a refill of your old ink cartridge or have bought one of those "re-manufactured" cartridges? The head in the cartridge is very sensitive - when they are damaged or poorly handled - it could result in cross contamination of the color inks. Hence - the brownish color you see could be the result of that cross-contam. My impression is that the remanufactured or older or continously refilled cartridges may be more prone to getting damaged - maybe bec of inherent wear out. Hope this helps.
Nov 30, 2006 | HP DeskJet 3325 InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
314 people viewed this question
Seeker5211
Seeker5211
