Question about Plumbing
To turn faucet handles off
Where I live, the bathroom fixtures are old. The tub and sink both drip often. Would there be anyway to get the handles tighter to stop the dripping. I don't have that much hand strength. Just want to slow down the dripping if possible. Thought of using some kind of tool, but that may cause damage.
    Problem Solver:
  • 4 Answers
Re seat the tap and replace the washer with a half ball round washer , will close easier.
Posted on May 24, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
Leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
May 26, 2010 | Grohe Seabury Roman Tub Faucet with...
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Jan 30, 2009 | Delta Victorian T2755-NNLHP Bathroom Roman...
Grohe Bathroom Faucet
If you don,t see any set screw for the handle, ( sometimes it is hidden under a small access cover top of the handle) Then the handle is threaded on where the base of the handle meets the sink/countertop surface. It is a right hand thread and will take a few turn before it comes off accessing the faucet stem.
Good Luck, Phil
Nov 05, 2008 | Plumbing
Plumbing Logo
121 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
