If you overcharged unit then u will get a frost build up on one of the lines coming off the compressor. if the compressor is not running then you will not get any cold air flow at all. if unit is stuck in defrost then no cold air will be dispensed either. you really need to check to see if you have a frost build up on the rear wall of freezer, if so then u are not going through defrost. to check proper level of freon u need a set of r12 gages. your level of freon will be displayed on the model serial number tag in fridge side. let me know and we will go futher.
