Question about Refrigerators
Ice o matic iceu150hw3 stuck in harvest - Refrigerators
  • dyna4310 May 25, 2009
    ice machine cycles on and off in harvest mode or defrost with hot gas bypass. never goes into freeze cycle. low on refrigerant r404?
  • 374 Answers
if there is low on refregerant,if you have an equiptment to install for charging try to install it,on suction side there charging port,mount the blue hose of charging manifold service gauge and the yellow service charging hose to the r404 refrigerant service valve tank,clamp a clamp ammeter to one line,mostly common line run your ac,take the rated ampere on manuals or on tag at backside of refrigerator,open service valve just crackdown the valve,in charging refrigerant just open a little for 5 to 8 second and closed service valve of a r404 refrigerant tank,repeat until you got the rated ampere on clamp ammeter,you can relay exact amount of refrigerant on rated ampere rating of your a/c.
this should be done by qualified a/c refrigerator technician if you can't do it try to call,on your service manual there is a contact number.have a nice day.regards
Posted on May 26, 2009
  • 73 Answers
What do you Mean by harvest?
Posted on May 24, 2009
Ice-o-matic 400ha2 ice machine wont harvest soon enough / ice to thick
There could be so many things wrong with it to cause this problem from just a dirty machine, bad harvest assist plunger, low freon charge, bad hot gas valve. You really need to call a service company.
Aug 29, 2014 | Kitchen Appliances - Others
Ice bridge to thick
there is a timer, adjusted by seconds, first make sure the condenser coil located under the ice bin is clean. the harvest is initiated by suction pressure once the pressure switch makes contact the time delay will time out initiating the harvest. you can fine tune the bridge with the time delay.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
MACHINE DOSENT HARVEST
be sure the thickness sensor is not turned out too far
Apr 03, 2014 | Ice O Matic Complete Units ICE0500HA
I have a ice o-matic model iceu220ha1 freezes but will not go into harvest
Go to Google put in model number ICE220ha1 when it comes up the fourth one down, Service parts manual The ice series under-counter... It is a PDF down load it then go to trouble shooting look for not going into harvest this will tell you what to look for.
Oct 24, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Does not go into harvest
There are two relays in the control box. One or both are brbably burned and will need to be replaced.
Mar 14, 2013 | Ice-O-Matic Ice O Matic ICE0400 Ice Series...
I have a Ice-o-matic, model number IC1006FAZ, the purge valve gets stuck after one harvest, it got stuck open, we open it and clean all the hoses, and unclug the valve, It happened before and it fixed the...
Pretty sure it is a bad valve. You can unplug the unit and disconnect the wires to the purge valve then plug the unit in again and try to make ice like that. If the valve leaks through with no power it is obviously bad. You note that you unclogged the valve in the past. I have taken a few of these apart and sprayed the internal diaphragm with food grade silicone lubricant but this is a very short term fix. I always wind up ordering and replacing the valve.
In the mean time you could plug the purge hose for a day or two. I would not run it too long like this because you will get a mineral build-up in the unit. The reason for the purge is that minerals do not freeze and wind up settling in the sump. Eventually enough mineral deposits build up to circulate and clog up the water tube and deposit on the evaporator plate. Some minerals are always going to stay in there and cause problems but with no purge they will REALLY build up.
Aug 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
