Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak pool heater piliot light on heat will not turn on
Raypak pool heater 2100 not digital piliot light on but when turn heat on will not run. Checked breaker and is fine.
  • 864 Answers
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
Humming noise in raypak 2100
if coming from gas valve or regulator replace if from heat exchange check manual bypass
May 15, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
1,671 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
