Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Will not complete rinse cycle
Will not finish the rinse cycle...this message appears LE...what does this code indicate?
  • 423 Answers
The LE stands for Leak Error. If you have confirmed that there is no actual leak, then the next thing to check is the routing of the drain hose. It is very common that that hose does not have a "high point" in the hose and the water is being siphoned out of the dishwasher and down the drain.
The quickest way to solve the problem is to raise the drain hose as high as possible under the counter and attach is securely. The BEST way to fix the problem is to install an Air Gap in the drain circuit (almost free at any real hardware store) but drilling may be needed.
Posted on May 26, 2009
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
Flashing LE and not finishing the cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 13, 2010 | LG WM-2277HW Front Load Washer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LE Problem
An LE Error Code is indicative of a ?Locked Motor? or ?Overload in the Motor?. This is rarely caused by a problem with the machine and in most instances resolvable over the phone. Q1:Are there suds in the drum? -->Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor. Follow the steps below to resolve an LE error code caused by oversudsing. --> Step 1: Unplug the unit and let machine sit for 30 minutes to allow suds to dissolve. Step 2: Press the POWER button to turn on the washer. Step 3: Press the SPIN SPEED button to select ?No Spin?. Step 4: Press the START/PAUSE button to begin drain only. Step 5: After cycle is complete, remove the items from the machine. Press POWER to turn on, RINSE&SPIN button, then START/PAUSE. Repeat, if necessary. This will remove excess suds and light residue from drum. Do this until no suds are seen in drum. Q2: Is this a new installation? -->In new installations, the code can appear simply due to a miscommunication between the control board and the motor. In this instance, the unit will simply need to be reset, much like rebooting a computer. Unplug unit, press and hold start/pause button for 5 seconds, plug unit in and test with a Rinse/Spin cycle. Q3:Is a large load size in a gentle wash cycle? -->Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle. Q4:Is the washer overloaded? -->Single bulky items (comforters) or extremely large loads can add extra weight to the drum which stresses the motor. Remove some clothing and restart. If it doesn?t work, unplug unit and let it sit for 30 minutes to allow motor to cool. Then restart the cycle.
Jun 09, 2007 | LG WM1814CW Front Load Washer
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
158 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
