Question about Gateway 503GR PC Desktop
Motherboard drivers I replaced the motherboard in the computer, and the supplied restore disk doesn't have the correct drivers for it. It also won't let me install the drivers at any point (like the regular Windows disk will). The computer won't boot into Windows for me to update the drivers.
  • gamma748 May 25, 2009
    The CD that I am using is the restore disk that came with the computer. I am trying to avoid buying a new copy of Windows, since I already have a valid license for the copy I have. I have the disk that came with the new motherboard, but I am trying to install those drivers without 1.) wiping all of the data off of the hard drive, and 2.) needing to buy an additional copy of Windows.
  • 272 Answers
There should be a driver cd for the motherboard. If that is missing, first find the model number of the motherboard. Go to the website of that motherboard. download drivers of INF, sound and graphics. Then do a fresh install from operating system cd. After finishing, setup the downloaded drivers. do not use the cd provided with previous motherboard.
Comment here if you have any problem doing this.
Posted on May 24, 2009
Z60m motherboard not recognized
Most restore disks are designed to work only with the ORIGINAL equipment. If you had replaced the motherboard with an identical unit the disks would have worked. But you used different board with different drivers, etc. What you can do is using another computer you can backup the files on your hard drive to a usb stick and then reload the hard drive with your OS of choice , load your programs and then transfer over your backed up files on the usb stick.
Mar 31, 2014 | IBM Lenovo ThinkPad Z60M Motherboard...
D945ghz
Intel D945GZ motherboard? Got it. Now what the world are you talking about? A Chassis Intrusion Switch? What desktop computer is it in? Computer manufacturer name, and Model Number. Post back in a Comment.
Wait a minute. Won't boot, or the Power Supply doesn't start up?
Power Supply doesn't start up;
1) You have a bad ATX power on switch
2) You didn't connect the ATX power on switch to the correct pins, on the Front Panel header.
3) You have a bad Power Supply
http://www.directron.com/atxswitch.html
Computer doesn't boot up;
1) You didn't follow Anti-Static Precautions
2) You didn't apply Thermal Paste to the top of the Processor, before you put the Heatsink on.
3) You didn't connect the 4-pin ATX +12 Volt power cable.
Power for the Processor. (No processor, no computer)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
4) You didn't use the Installation Disk (CD) that came with the motherboard. (Has the DRIVERS)
5) Is this a replacement motherboard for a bad one?
SAME motherboard, or a different one?
Why?
Because when Windows is installed on a computer, (Harddrive, actually), it assigns hash values to certain major hardware components.
Components such as;
1) Processor
2) Motherboard chipset
3) BIOS program, version, and date
4) Harddrive
5) Graphics chipset. (Whether Integrated Graphics, or a graphics card)
Change any two of these components, and Windows will think it is being stolen.
Microsoft User's License states, "ONE Genuine copy of Windows per ONE computer "
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
If you are lucky, the Windows activation screen may come up. Windows will want to be activated again. (Activated, not Registered)
Doesn't happen all the time, though.
Using a brand new genuine copy of Windows? Make sure you go into BIOS Setup, and in Boot Order, set the first boot device to CDROM.
The LED light on the motherboard indicates it HAS power.
Motherboard Manual for the Intel D945GCZ mobo. (MOtherBOard),
(GHz stands for GigaHertz.
Giga = approximately 1 Billion.
Hertz stands for Cycles per Second.
1GHz = approximately 1 Billion Cycles per Second.
It refers to Frequency Rate. For laymen frequency rate = 'Speed')
Plus, it isn't new. It is NOS. New Old Stock.
Means it could be a bad motherboard, even if it has never been used.
{Computer technology follows Moore's Law,
http://en.wikipedia.org/wiki/Moore%27s_law
What is new technology today may be old tomorrow }
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Blue -> English Product Guide [PDF]
Let me know if you think there is a Chassis Intrusion Switch.
It will operate one of two ways;
1) When the cover is removed, the switch is open. No connection of the two wires is present. Remove the switch, put a piece of heat shrink tubing over one wire, and slide it back out of the way.
Twist the two wires together with an Electrician's knot, solder them, slide the heat shrink tubing over the connection, use heat to shrink the heat shrink tubing.
2) When the cover is removed, the switch is closed. The wires are grounded out. Remove the switch. Cut the exposed bare wire off, leaving just the insulation. Put a wire nut on it. Do the same for the other wire.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 24, 2012 | Intel Computers & Internet
Do I need a CD installalation disk to install Cd drive, 8480C in my computer?
yes you will need the installalation disk or try and see if they have a downloadable install installalation for your cd drive.
Dec 21, 2011 | LG CRD 8480C (CRD-8480C) Internal 48x...
My desktop suddenly suspended, switched it off by pressing the power button. Now it does not boot, the screen stays dark, though power lights on the PC and keyboard are on. What should I do?
You are the owner of a desktop PC that has developed a sudden and catastrophic hardware
fault - probably on the motherboard (since even the ROM BIOS doesn't give evidence of its
existence), but possibly in the power supply.
Desktop PC power supplies are (relatively) easily replaceable, so if you have as many spare
power supplies lying around as I do, try replacing that first - if that doesn't fix the system, then
the problem is on the motherboard.
Since your power supply is alive enough to light the power LEDs on the system unit tower and
also the keyboard, the problem is probably on the motherboard - look at it - there may be an obviously burned visible component - but there usually is no visible sign of the fatal failure.
The reason I do not suspect your HDD (hard disk drive) has crashed is that ROM BIOS
executes at (power start) boot time right out of motherboard-mounted ROM, independent of
whether or not the HDD is functional - and since not even the BIOS message appears on your monitor, I therefore know that the boot sequence has been interrupted long before the computer becomes intelligent enough to find and access a disk drive, and then command it to try to find a
boot sector.
How to fix the computer: isolate the boot problem to the motherboard. Replace motherboard.
Sep 05, 2011 | Epson Computers & Internet
Hi..i have a computer name DELL model: DHM, the serial no: 9QXPX21. my problem is, if I press power button, the motherboard detect lights but doesn't work, i try to change power supply, memory and I...
Make sure your power supply is set for the correct region you are in, if that does not work, check the obvious stuff like your monitor having power and being on and all that. If that doesn't fix it your Motherboard is likely fried and you will have to replace it
May 31, 2011 | Dell Computers & Internet
I have a Dell Optiplex 960 in which the motherboard had to be replaced. When I try to install nvida quadro 420 the machine reboots and will not go into windows
Could be a bad power supply. If the power supply can not handle the nvida quadro 420, the computer would be forced to restart. You computer doesn't essential need a graphics card to work. The mother board has one embedded so your desktop can run without it. My suggestion is to take the card out, reboot it, and find the correct drivers online before putting the card back into your motherboard.
May 12, 2011 | Computers & Internet
I just build a computer with a Gigabyte motherboard and installed XP home edition and now I'm trying to install the drivers for the motherboard and installed the disk with all the drivers on it and it...
Try the disk in another machine and see if it works, if it does power down the pc and double check the drive is installed correctly.
If it is just the disk that's got an issue, you could try downloading the driver for your motherboard from the web. This should be a good place to start: http://www.gigabyte.com/products/product-page.aspx?pid=3500#dl
Thanks.
May 10, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Have three gigabyte ga-945gcmx-s2 motherboards but have lost installation disks, can you help. i have two running including this one but i have rebuilt another and i have no installation disk
Start at this link:
http://ggts.gigabyte.com.tw/tech.asp?ClassID=2&Country=Canada&SourceWeb=B2C
Getting the correct motherboard support drivers may depend on answering all the questions correctly on this site.
ie, you have to have your motherboard manual and the serial number of your motherboard ready.
These major motherboard manufacturers can often supply support software in the form of updated drivers that can get you going again, but you may have to jump through some hoops by supplying correct info about your product.
Alternatively, the dealer you bought your motherboard from may have a spare support disk they may give you. However, these items are subject to continual update and replacement, so act fast.
Please feel free to get back to me on your progress.
Oct 27, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Computer won't come on
I had the same problem, I unplugged my computer to move it before it had fully powered down. It wouldn’t start and all I got was the flashing lights.
I asked a friend who suggested I remove the power to the motherboard then reinsert it while it’s hot. Here’s what I did. Unplug the computer. Touch something metal so you’re grounded and don’t create a static shock on the motherboard. Now GENTLY pull the 16pin wire harness off the motherboard. Now plug the computer power cord back in. Then GENTLY plug the motherboard back in. With any luck the fan will start up and the computer will begin booting up. It seems to be some type of problem where the power supply doesn’t recognize the motherboard so it doesn’t do anything until it “sees it”? Probably some type of a safety to prevent motherboard burnout?
Oct 20, 2008 | HP Pavilion a705w PC Desktop
Dvd/cd drives
Looks as though you have lost or corrupted the drivers. Assuming you are on XP (?) try restoring your computer to an earlier date.
Start -Help and support - undo changes with sytem restore
Apr 10, 2008 | Computers & Internet
Gateway 503GR PC Desktop Logo
215 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
