Question about Car Audio & Video
CD/DVD Player will not take CD or DVD In All the Way
Each time I put a CD or DVD into my player, the CD/DVD seems to get caught on something and won't allow the CD to enter the player fully. It also cause a large amount of scratches on the outtermost edge of the CD when it has been ejected out. The CD never gets stuck in the player, but it also never has the ability to fully enter the player to allow the player to read it. Can you help?
  • joker54504 Feb 26, 2008
    i put a cd or dvd and it just ejects back out wont play just happened one day no symptoms prior xdvd 8181
hardrocko
  • 1476 Answers
SOURCE: dvd won,t eject
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
Posted on Jun 26, 2006
SOURCE: DVD Stuck in player
Found out what my problem was - 2 DVDs were in the unit - need to take unit out of car (very easy - 5 mounting screws, 2 plug in power connections), remove some brackets from within the unit to get to the DVD itself and then just pull the DVD out - took me less than 1 hour - and I am not tech savvy or mechanically inclined by any means
Posted on Jun 29, 2007
  • 93 Answers
SOURCE: CD player ejects CD
ok,replace the belt in spindle motor,that is only problem
Posted on Oct 26, 2007
SOURCE: dvd player wont eject or load..........
http://www.fixya.com/support/t208832-lite_lvc_9016g_dvd_drawer_not_open
Posted on May 22, 2008
  • 3 Answers
SOURCE: Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Posted on Aug 11, 2008
My dvd won't play on my computer
The DVD region code does not match the Region code for the DVD Player and the Country set in the time and date settings.
Sep 06, 2012 | Dell (Inspiron 531) PC Desktop
I put Windows 7 Ultimate on my computer, now windows media player won't read from my cd/dvd, but real player will play from it. It says I have 14 tracks all the same length and time.
on system start up time press F8 key for no of times.you can see some option from that you can select repair and continue with options given
Mar 12, 2012 | Computers & Internet
I purchase this system or a christmas present I had it put in today and it works great except the cd player will not except the disc. Please help me with this problem.
does there seem to be something obstructing the cd as you are trying to put it in? some inexpensive decks use cd transport screws on the top of the radio, and they need to be removed before a cd can be taken into the cd mechanism.
Jan 18, 2011 | XO Vision XO1915BT Car DVD Player
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Error C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
May 16, 2008 | Sony DVP-F25 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
