Question about GE APH10AA Air Conditioner
Capillary tube for a GE APH10AA Portable Air Conditioner?
I have a GE APH10AA Portable Air Conditioner. It has worked great for about 4 years, but it recently stopped blowing cool air. I took it apart and found the capillary tube is bad. I want to replace it, but I can't find them anywhere. Does anyone know where I can get this capillary tube? I'd much rather replace it than spend $300 on a whole new unit. Thanks!
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
ranger25
  • 72 Answers
SOURCE: GE APH10AA - beeps once when plugged in but doesnt turn on
It could be just the start capacitor for the compressor that has gone out. Easy way of checking is to take a screwdriver and short across the leads after you have unhooked it from the wiring connectors (don't touch metal while doing this, it CAN shock you) and take an analog meter, put it on ohms for resistance, and touch it across the two connectors. The meter should jump, then switch leads and touch them again. It should jump consistently like this. If it's not that, then it's probably either faulty wiring, switch or if all else fails it could be the compressor went to ground. Take off the leads going to it, again set the meter to full resistance, and put one lead on copper tubing going into the compressor, and touch each pin of the connector on unit. If any of them read anything, then it is the compressor. Hope this helps.
Posted on Jan 27, 2008
  • 182 Answers
SOURCE: GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Posted on Nov 05, 2008
  • 659 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
  • 334 Answers
SOURCE: ac capillary tubes
Sounds like you have a clogged cap tube. Yes they should both be sweating, I would expect your low side pressure to be lower though unless it is real hot in the camper. You can replace the tube but make sure what goes in is the same diameter and length because that is all engineered for proper metering into the evaporator.
Posted on Jun 11, 2009
GE APE07AHM1 Won't Run
This unit has a famous problem with the control panel. Try to use the remote to turn it on, instead of the panel. I had the same problem.
Jul 18, 2013 | GE APH10AA Air Conditioner
Hi, I have a GE Portable 120 Volt Room Air Conditioner Model: APH10AA. It is producing a humongous quantity of water every times it runs. For 8 hours of use at night, it produces close to 3 gallons of...
with real high humididty this will be a problem I might suggest that you find some kind of pair and place it inside the pail but stacked onotp a a block to keep the unit dry until things dry out a bit .. Its the weather not the unit thats the problem let me know
Jul 23, 2011 | GE APH10AA Air Conditioner
Where do i put the water in? i have a ge stand up ac
If its a AC unit, you add no water. If its a humidifier you add water, but you do not want humidity this time of year.
Jul 03, 2011 | GE APH10AA Air Conditioner
I need the flexable hose and adapator that expells the exhaust heat where in ft.worth,tx can I find these parts. Thanks
You could try GE Parts Service. You will need the correct Model Number of your portable AC Unit to do this. https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Air%20Conditioners
And you can also try Factory Appliance Parts. Again, you will need the correct Model Number .
http://www.appliancefactoryparts.com/airconditioners/ge/allmodels.html
Hope this helped to get you started. Please let me know. Thanks.
Jun 20, 2011 | GE APH10AA Air Conditioner
I have a GE APH10AAG1 portable ac that has no control panel function. It does turn on and blow cold when pluged in. It does have some LED's that light up (dry, low fan and the display). But none of the...
I have the same problem, Just use it with its remote control. if you dont have it you can order it through sears parts : part# DG11A2-04 (GE) or 81401789
Sep 23, 2010 | GE APH10AA Air Conditioner
I have a GE APN10AA portable A/C unit haven't used it in a few years and I think that you need to put water in it prior to running it but can't find the owners manual - any help
I have the APH10AA model and the manual is compatible with the APN10 model as well. It claims that with regular use the unit produces water on its own. It has a built in evaporator but may occasionally have to be drained. A manual for this unit can be found at GEAPPLIACES.COM. Just need to input your model number and search "use and care manuals" in the top right corner of their site.
Jun 29, 2010 | GE APN10AA Portable Air Conditioner
Does the unit suppose to retain the water?
No. The unit is not supposed to retain water. By product of a/c or
refridgeration is water due to air being cooled below dew point of air.
(Check your uninsulated cold water pipes on a hot, humid day. They
are usually sweating.) The tubing should be routed to drain or outdoors.
Jul 24, 2009 | GE APH10AA Air Conditioner
APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
Aug 05, 2007 | GE AGQ08AH Air Conditioner
GE APH10AA Air Conditioner Logo
180 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
