Question about Lanzar VIBE266 Car Audio Amplifier
Amp turning on and off
I have one 12 inch sub in my car and recently have been having some problems with the amp. If the RCA wires are not connected to the cd player the amp stays on and no problem. But as soon as the RCA is connected to the cd player the amp is constantly turning on and off when i turn the volume up but when the volume is very low the amp stays on even with the RCA connected. I am positive it is not the RCA wires because i tried using another pair of RCA wires and it still didnt work.
KaeZoo
  • 156 Answers
SOURCE: amp LED flashes on but right back off
This sounds like a problem with the power input to the amplifier; it's possible, but unlikely, that your CD player is causing it. Before you can do any real troubleshooting, you need a voltmeter. When your CD player is turned on, you should get a voltmeter reading of around 12 volts at the amplifier's remote terminal and B+ (power) terminal. If your main power wire doesn't show voltage, check for a loose or corroded connection at the battery or fuseholder, and try replacing the fuse (even if it looks okay). If there's no voltage on the remote wire, it may be pinched or shorted between the CD player and the amplifier, or the CD player may be faulty. If you get a good voltage reading on both wires, but the amp won't turn on, then you have a problem in the amplifier.
Posted on Mar 07, 2007
SOURCE: Protection Light Is Coming On
ok, sorry to hear that
Posted on Jan 09, 2008
  • 631 Answers
SOURCE: Protection Light irritation
If the amplifier goes into protect when there are no speaker wires connected to the amp, the amp is likely defective. The most likely culprit is shorted output transistors. If it's new, return it to the place of purchase for repair/replacement.
Posted on Jan 11, 2008
zzedly
  • 300 Answers
SOURCE: wiring
In all reality, that amp is probably a bit small for those two subs. To maximize the power from the amp to the subs, make sure:
  • The dual voice coils of each sub are in parallel (+'s together, -'s together). This makes each sub 2 ohms.
  • Connect the subs in series (+ to -). This makes the combination of subs together 4 ohms.
  • Bridge the 2 channels of the amp to the subs in series (see above).
This will put somewhere between 150-200W to each sub.
Keep in mind, though, that depending on the music type and location in the vehicle, the type and size of the sub box is going to make almost as much difference as how much power is on the subs. Sealed boxes are usually small and have a nice flat response, but tend to need more power to sound louder. Ported and bandpass boxes are larger and aren't as flat of a response, but have nice loud peak at a certain frequency.
Let me know if you need any more help!
Posted on Mar 24, 2008
  • 631 Answers
SOURCE: Annoying thump from two 15" kicker comps powered by a lanzar vibe 266 amp
It sounds like it may be oscillating. This can be caused by a broken ground in the signal line. You need to check the RCA shield on the head unit.You'll need an ohm meter. The following page has more details. If the head unit isn't damaged, the shield ground could be open in the amplifier.
Temporary Shield Repair
Posted on Apr 05, 2008
How do I hook up a jbl 12 inch subwoffer to a car head unit
The head unit should have a RCA Sub Out. The RCA wire goes to the Sub Amplifier, along with power, ground, and a blue remote wire from the Head Unit. Next, the Sub Amp is wired to the Subwoofer with speaker wire. Without an amplifier your sub won't make any noticeable sound.
Oct 09, 2011 | 1998 Ford Taurus
I have put dual 12 inch subs in my 1999 camaro and I hooked the power wire from the amp to the radicand the subs are working but not to full power. when I go on the radio to turn my subs on it wont let me...
check the remote wire it it needs to be hooked to the atenna power wire on the radio the power wire to the amp needs to go to the BATT. with a fuse make sure your amp is grounded well and less than 18 in. then check your RCA wires after all that then go back and check your sub output on your radio
Sep 20, 2011 | Kenwood KVT-514 Car DVD Player
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
Backfeed problems
back feed can be caused by running your rca's beside your power wire, and if you don't have your remote wire connected properly your amp might not turn on, or off depending on the amp. it could also be your power wires (acc and constant power) on your deck are mixed up, you would be able to tell if it cant remember the time
Mar 17, 2010 | Sony Car Audio & Video
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
Alpine amp wont turn on..
your power wire is sufficating yor amp probably
Jul 29, 2009 | Kenwood KAC-8152D Car Audio Amplifier
12 inch subs emit engine noise
You will have to go buy noise filters for the headunit. This will stop engine noise
Jan 31, 2009 | Precision Camera Precision Audio 12-inch...
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
55 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
