Question about HP Pavilion F1703 17" LCD Monitor
Monitor power supply
If my monitor required a 12v 3.75 A Woould a 12v 1 amp power it up.. Even for a few seconds
  • 78 Answers
Yes it will work a short time...
Posted on Jun 19, 2009
    Problem Solver:
  • 13 Answers
Most likely you will damage the 1Amp power supply if you try using it. Most devices draw the highest currant when they are powering up.
Posted on May 24, 2009
Whiching power supply 12v not working
I guess you mean "switching". It is not worth fixing. It can be replaced. You should find a power supply rated 12V with the Amp rating the same or higher than on the old one. Higher will not hurt, because the 12V and the resistance of the device determines how many Amps will flow. The rating is the highest amount it can safely supply. It is like when you have a 1/2 ton pickup truck, you don't have to carry 1/2 ton all the time.
Apr 26, 2014 | Computers & Internet
How can i find a power cord to fit this monitor? The one I have is not getting power to it . It was tested by Best buy.
Most monitors have the same type power cord. You can order them cheap off of Amazon and eBay.
Heres on that should work: http://www.amazon.com/Cables-Go-03134-Universal-IEC320C13/dp/B00005113L/ref=sr_1_1?ie=UTF8&qid=1298845316&sr=8-1
Feb 27, 2011 | Envision EN 9110 19" Flat Panel LCD...
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
B&W PV1 Subwoofer
Make sure that your amp is putting out proper signal to the sub woofer.
If the feed from the amp is okay, the power amp and our the power supply in the sub woofer may have become defective. This will require to be serviced.
Jerry G.
Jun 13, 2008 | B&K AV 125.7 7-Channel Amplifier
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Mag lt456s power supply bad
The correct one would be 12v @ 2.5 to 3 Amp.
If the set used less current than 1 amp it would be in milliamp (500ma which is half an Amp)etc.
As long as you get one that is 12v @ 2.5 to 3 amp it will be fine.
You could buy one with a higher current rating like 4,5,6 or more Amp's as long as it's 12v DC. The set will only use the current that it needs to function so I higher current won't hurt. It's the voltage you have to make sure is correct. If you do buy one with a higher current rating it will probably last longer because it wont get so hot.
Mar 12, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
1501 power supply
The screen comes standard with a LiteOn power supply, 12v 3.3amp
Dec 21, 2007 | HP Compaq 1501 15" LCD Monitor
LM1770A POWER ADAPTER 12V
Ok well the Power adapter is not really that special.. what you need is a Centre Pin POSITIVE 12volt at say 4 amp power supply unit. I would get it from Ebay.. perhaps even being able to get an exact one from Ebay.. Othewise try the Samsung site and purchace direct. Look here for an idea. http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=power+supply+for+LCD&_nd1=See-All-Categories
Jul 31, 2007 | Samsung Techsan LM1770A 17" Monitor
HP Pavilion F1703 17" LCD Monitor Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
