Question about GE 7.0 Cu. Ft. Super Capacity Gas Dryer - White
GE Gas Dryer Model #dbvh512gfoww heat problems
My dryer is about 3 years old. Recently the dryer went from working fine to having almost no heat.
First, yes I have opened and cleaned all duct work and also opened up the dryer housing and cleaned out the blower motor, lint duct work, etc.. There was a fair amount of lint build up but for 3 years worth of use I would say it was okay.
Now, onto the problem. I start the cycle and the dryer starts with decent heat for a few minutes then loses all heat completely after a few minutes. I look at the bottom peak hole on the underside of the unit for the igniter glow and yes it glows for about 5 secs then shuts off then repeats the process about 30-45 seconds later but doesn't have any real signs of heat.
Seals look good, everything cleaned out and yes my gas line is turned on.
Thanks.
  • p_petko May 25, 2009
    Thanks Vic. Sounds like the problem to me also after all the researching I've been doing. I will order the coils and hope for the best. It will be nice to have a working dryer again considering the money my wife spent on it.
    President:
  • 1,136 Answers
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
Posted on May 25, 2009
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
I have an older GE model DDG7980GDL dryer that does heat. It will go on sometimes but it is getting far and few between those times. I can hear some noise from the front of the gas valve like it is trying...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Dryers
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
Ge front load dryer not heating three years old model # dbvh520ej2ww
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Dryers
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer is spinning but the burner wont fire up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Ge dryer model dbvh512gfoww not heating can hear ignitor clicking but will not light
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uifg
Nov 02, 2009 | GE DBVH512GFWW Dryer
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
GE 7.0 Cu. Ft. Super Capacity Gas Dryer - White Logo
575 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
