Question about Toshiba Satellite 1130-S155 Notebook
Won't boot up. Get a message early on in the process that says the following file is corrupt or missing: Windows\system32\config\system Recovery disk won't boot either
  • 696 Answers
This problem usually occurs due to an ungraceful shutdown, ie battery died before the laptop completed it's shutdown procedures or due to a failing hard drive.
Try booting the laptop and pressing F8 repeatedly. When the black and white screen pops up you can try booting into safemode/Command prompt. If you get in to the Comand prompt, type, CHKDSK /F then restart the computer by pressing Ctrl-Alt-Del all three at once.
When it restarts it should go into disk checking mode, let it run and if it's only minor damage this should solve the problem, if that doesn't work, put your windows recovery disk into the DVD drive and boot the laptop, when it starts asking you questions try running the REPAIR install and this may solve the problem.
If neither of the above work you may need to recover the laptop to factory settings(same disks) but should backup any important files you have saved first. If you do not know how to do that already I would advise seeking a pro for at least that portion as it is easy to accidentally wipe out all of your files.
Hope this helps FixYa,
Chris
Posted on May 24, 2009
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Why won't the hard drive activate on my acer aspire one 522, the bios can see it.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time. http://www.fixya.com/support/r4482455-repair_windows_xp
Apr 05, 2013 | Computers & Internet
Windows Xp won't start
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to useWindows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Feb 17, 2013 | Dell Dimension 2400 PC Desktop
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Jun 16, 2012 | Acer Aspire 3000 Notebook
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Windows will not boot on my Eeepc 1005HA. 0xc000000f -- The boot selection failed because a required device is inaccessible. I have tried to reinstall windows7 from USB (tested and working) but boot...
BootSuite is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jul 11, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Problem booting up dell dimension 2300 desktop.
You have no choice either you should reinstall your system, you should provide windows CD/DVD installation and boot your system using this disk.
However; you should backup your important files be cause most likely the all files will be removed during the installation process.
Jan 04, 2008 | Dell Dimension 2300 PC Desktop
Toshiba Satellite 1130-S155 Notebook Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
