Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas
Wont ingnite or switch to pool setting
Pool heater will only switch to SPA function. The pool light does not illuminate. I only have a pool. Last year, same problem and I needed to replace the fuse. This year that did not help. The fan will kick on for when I select SPA, but the burners do not ignite but I get e few clivking sounds. Ater a minute or two of the fan running stops running and I get an AGS error message (automatic gas shutoff)
    Top Expert:
  • Teledyne Laars Master
  • 6,949 Answers
Sounds like need new ignitor
Posted on Jan 14, 2016
4 Suggested Answers
SOURCE: Pool heater burners won't ignite.
Also you need to inspect the igniter.
Posted on Apr 25, 2009
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
StepehnD
  • 78 Answers
SOURCE: My Laars LX pool heater would shut off soon after it fires up
This error is Automatic Gas Shutdown. Here is what you can do:
  1. Check for fluctuating pump pressure (air in strainer, pressure guage bounce)
  2. Check all wiring connections
  3. Replace ignitor/flame sensor assembly
Depending on your expertise, it could also be the gas valve or ignition control (aka the IID).
Since the burners do fire briefly, I would suspect the flame sense rod first. Attached is a link to the owners manual in PDF.
Lo Nox heaters can be a little tough so follow the directions exactly.
Posted on Jul 25, 2010
The red light on heater won't turn on
This is an indication that the pressure switch is not working. When it completes the circuit thru the pressure switch it send power to the heater. It is the last fail-safe before power goes to the heater.
Bath & Spa Parts Online
Balboa 3 Amp Spa Heater Pressure Switch 2 0 PSI 30408
Aug 09, 2016 | Pool & Spa
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
SPK displays on Raypak 2100
check gas supply if ok check to see if gas line to ignitor free of debris
May 24, 2012 | Raypak 2100 Pool Heater Gas 266000 BTU'...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
When I turn on my pool ,the heater wont turn on.
clean the filter turn breakers off for twenty secons
Sep 06, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas  Logo
88 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
