Question about Microsoft Outlook
Need to save and transfer all e-mails to a new computer
Can someone describe to me a step by step procedure in saving all my current e-mails and all folders in MS Outlook so I can install them on a new computer. I've read some info, however I do not even know how to locate the Outlook file in the C drive
  • gearjammer21 May 24, 2009
    This looks like it will be fairly simple. I will give it a try. Another question. Will this proceedure copy my address book as well or is there another procedure?
    Not having much luck with this. I managed to save this pst file to my desktop, however when I tried to copy it to a flash drive, a pop-up came up and said unable to complete because something was blocking it. What could that be. Also, when following instructions to copy the Outlook address book, when you open the address book, then click on file, the try to click on import or export but the text is not high lighted. Can someone tell me why the text is still shaded.
    President:
  • 623 Answers
First of all, I assume that all the email account settings have already been setup within Outlook on the new computer (as you have been using Outlook on the new computer successfully to send and receive email).
If you want to transfer your files you will need to copy the Outlook PST file from your old computer to your new computer.
To find the location of the PST file, open Outlook on the old computer and in the left-hand pane you should see a listing of all your email folders, with the root heading being “Personal Folders”. This is your Personal Folders PST file which contains all your email.
  1. Right-click on the “Personal Folders” heading and select “Properties”.
  2. In the Properties window that appears for Personal Folders, click the “General” tab and the “Advanced” button.
  3. In the next window that appears there should be a field called “Filename”. This denotes the location of the PST file which contains all the email and folders within your Personal Folders PST file. Write down the location of the PST file and then click “Cancel” twice to close the two open windows. (It should be someting like C:\Documents and Settings\<username>\Local Settings\Application Data\Microsoft\Outlook\outlook.pst)
  4. Open Windows Explorer or My Computer and navigate to the location of your PST file. Be aware, you may need to enable the display of hidden files and folders to see the path to the PST file, as it might be a hidden path. To do this, go to the “Tools” menu > “Folder Options”. In the window that appears, click the “View” tab and enable “Show hidden files and folders” then click OK to save and close.
  5. Once you have located the PST file you can confirm that the file is correct by looking at the size of the PST file – it should be quite large - mine is about 1.2 GB!
  6. Copy this file to a USB hard drive or USB stick if you have one that can hold the size.
  7. Once the file has been copied to the USB hard drive, disconnect the USB hard drive from your old computer and then connect it to the new computer.
  8. Copy the PST file to a memorable location, such as the desktop (this is only temporary, and this PST file will be removed once the email transfer has been completed).
  9. Now it is time to import the contents of the old PST file into your installation of Outlook on the new computer by using the in-built Outlook import function.
  10. Open Outlook on the new computer then go to the “File” menu > “Import and Export”. The Import and Export Wizard window will appear.
  11. Select “Import from another program or file” and click “Next”.
  12. On the next screen asking you to choose the file type, select “Personal Folder File (.pst)” and click “Next”.
  13. The next screen will ask you to select the file to import.
  14. Click the “Browse” button and navigate to the location to which you copied the PST file from your old computer (in our example before this was the Desktop).
  15. Under “Options” select one of the options depending on how you wish the import to behave. I suggest you leave this at the default setting of “Replace duplicates with items imported” as you should not have any duplicates.
  16. Click “Next”. This last screen before the import allows you to specify exactly what should be imported. If you wish to import everything from your old PST file (i.e. mail, calendar, contacts, etc.) then underneath “Select the folder to import from” choose the root “Personal Folders” node as this will import everything underneath “Personal Folders” in your old PST file. As you can see, this includes emails and also the calendar, contacts, and other folders.
  17. Make sure “Include subfolders” is ticked and enable “Import items into the same folder in” then select “Personal Folders”. This will import all the data under your old Personal Folders into your new Personal Folders.
  18. Click “Finish” to commence the import. It could take a while considering the number of emails which need to transfer across.
Once the process has completed check the results. If you are satisfied then you can safely delete the copied PST file from your old computer to the desktop, as all the data from that file has been imported into your PST file for your installation of Outlook on the new computer. I would advise to burn it on a CD/DVD (depending on the size of the file) or store it somewhere else - it is always a good idea to keep a backup.
If you have any more questions or this description is not clear to you, just come back here and leave a comment - I'm happy to help.
Posted on May 24, 2009
  •  C. Dante
    C. Dante May 25, 2009
    When you copy the .pst file, make sure that Outlook is not running, or you will get an error message that the file can't be used because it is in use by another program.
    The .pst file is a complete file containing all information from Outlook, including mails, contacts, and calendar.
    Copy the file from C:\Documents and Settings\... directly off your computer to a USB drive/stick or burn it to a CD/DVD. Outlook is very picky if it finds a second .pst file on your computer.
    When you were importing, did you choose "Personal Folder"?
    In that case it will import everything including mails, contacts, calendar without the need of importing each single folder individually.
I used to come with the problem,and i have solved it with a popular Outlook recovery tool called Advanced Outlook Repair .
It is a powerful tool to recover messages, folders and other objects from corrupt or damaged Microsoft Outlook PST files.
Detailed information about Advanced Outlook Repair can be found at http://www.datanumen.com/aor/
Posted on Jun 05, 2009
  • Microsoft Master
  • 4,806 Answers
Hi there.
First of all you have to export any emails you want saving to pst file on your desktop.
1st create a new folder on the desktop and name it Outlook or something similar.
2nd open MS outlook and click on the file tab, click on import and export, a new window will pop up and you choose export to a file and click on next, look down the list of file extensions and select personal folder file (.pst) and click next, in the next window select the email folder you want to save, inbox for example, include subfolders if you have to and click next, in the next window click on where it says browse and navigate to the newley created folder called Outlook that you created, call the file name inbox.pst and click OK, then click finish.
Do this action for all the folders you need to save making sure you name the file accordingly so you know where they came from.
Once you have saved all the emails you can copy the new Outlook folder to a flash drive or CD.
When you have your new operating system installed any you have your office suite on, to copy the emails back do the same again but this time you need to import from a file, just navigate to your saved Outlook folder and keep doing that until all your saved emails are back on the system.
Post back if you need anymore assistance.
Good luck and thanks for using FixYa!!
  • Lee Hodgson
    Lee Hodgson May 24, 2009
    Yes you can save your address book to, just make sure you name the pst file that.
    Kind regards and good luck
  • Lee Hodgson
    Hi again.
    In relation to your question about the pst file not copying, are you making sure the MS Outlook program is closed down before you try to copy it to your flash drive? Some files won't copy if another progam is using them.
    To copy your contacts or address book, open Outlook and click on file, then import and export, select export to a file and click next, then select Comma Separated Values (DOS) and click next. select the contacts folder and click next, name the file and save it in the folder you created, click next and it will be saved where your pst file is.
    Close Outlook and you should be good to go and save it to the flash drive.
    Good luck
How to save my text messages
Hi, to save your text messages, you can use this tool: SynciOS., Go to My Device>Information>Messages, click on Save button to save your text messages in txt format.
Jul 27, 2014 | Apple iPhone 3G
Tip
How to change password for yahoo account?
Your yahoo password is your key to all of the services offered by yahoo, including the popular mail and messenger features. To protect your personal information and and correspondence, it is important to choose a password that is difficult for someone else to guess. If you feel that you need a stronger password, or if you have reason to believe someone else may have your current password, it is a good idea to change your current yahoo password.
So, Please follow the below step for change your yahoo password.
Step 1: Sign in your yahoo account.
Step 2: Click your name, and click "Account info." (Note that you can also access "Account info" by clicking your name at the top of other yahoo pages while you are signed in.)
Step 3: Click "Change your password"
Step 4: Enter your current password and your new password, and confirm your new password.
Step 5: Click "Save".
A good password should not contain common words or words that are easy to guess. For instance, names of family members or pets are not good choices. Yahoo passwords are case sensitive and yahoo recommends users create passwords that use both lowercase and uppercase letters. Add numbers to your password to make it harder to guess.
Thanking you
davevipul197
on Dec 29, 2010 | Yahoo Mail
How do I convert apple mail to entourage 2008
To transfer all those amount of emails in different folders, have a look at this here:- http://www.mailexporterpro.com/export-emails-apple-mail-to-thunderbird.html
You can do the same steps in order to transfer your mails to entourage. Thank you.
May 19, 2013 | Apple Macbook Air 11.6" Laptop Mc505ll/a...
I DO NOT KNOW HOW TO PUT MY EMAILS THAT ARE IN THE TRASH INTO A FOLDER TO SAVE THEM. CAN YOU HELP ME?
Depending upon your email program, click on the trash folder then click on the email you want to save and then click on transfer back to the IN folder or to a folder where you want to save the emails.
Apr 16, 2011 | Computers & Internet
How do I down load my old xbox games onto my new xbox 360 60GB HDD. What cables do I need to connect to my PC which is Windows XP and I'm on broadband. I need a step by step procedure please.
u cant the only way to transfer games and saves is by using a usb flash drive or a hdd transfer cable which are 15 pounds to buy
here is link to cable CLICK
Aug 27, 2010 | Microsoft Xbox 360 Elite Console
Hi i am having htc touch mobile i want to know how to save all my sms in my storage card please help me
There is no setting that i know off that can transfer the SMSes to the storage card.
However, if you are looking to save the smses on your pocketpc, you can use this software called Pocket SMS. This will create a copy of your sms on the computer. Later you can transfer the data to the storage card for safe keeping.
Its available free at the link given below
http://handheld.softpedia.com/get/SMS/Pocket-SMS-Pocket-PC-60249.shtml
Hope it helps.
Regards,
Paritosh
Jun 18, 2009 | HTC Touch HD Smartphone
To transfer tape data to computer
the way you can transfer your videos on your computer is by using USB cable and install the driver to your computer. You can upload your videos by saving it on ULEAD products. As far as i know you cant transfer videos from disc to your memory card unless it was been converted but you cant view or watch it on your camcorder itself only computer can play this because your camcorder is not able to play such converted files.
i will give you a step by step on your camcorder.
  • connect your camcorder using your USB cable to your computer and be sure it is ON
  • Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
  • after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
  • Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
  • after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
  • burn your videos on NERO software
Hope you understand my procedures. Let me know if you have problems Good Luck!
thank you for using fixya
CHARCOIS
Nov 15, 2008 | Sony Handycam DCR-HC30E Mini DV Digital...
Trasfering emails and contacts from Windows Mail to Outlook Express
Hello
you can do it in many ways but I think this is the simplest.
copy addressbook
1. go to file>export>windows contacts
2. and save it to same backup folder on your desktop
copy msg
1. create a folder on your vista desktop(backupmail)
2. start vista mail
3. drag your messages that you want to the XP computer to the desktop backup mail folder you most drag emails you cannot drag and drop folders.
4. when you are done move the folder on a USB stick or something and move it to your desktop on your xp computer.
copy addressbook
1. go to file>export>windows contacts choose CSV
copy your mail account.
1. go to tools>accounts>export
2. save the file in you backup folder on your desktop
then copy the backup folder on your desktop to a usb stick or something to transfer it to your xp computer
your xp computer.
import msg
1. paste the backup folder to your desktop
2. open outlook express and drag and drop the msg from the backup folder on your desktop
import contacts
1. click file import "other addressbook" and choose "text file" navigate to the desktop backup folder and you should find a file to import click OK.
import account settings
1.go to options> accounts
2. then mail tab and click import button
3. navigate to the backup folder on your desktop and choose the iaf file to import
then you are done
good luck hope I helped, get back to me if you need more help.
Sep 18, 2008 | Microsoft Windows Vista Ultimate Edition
How to transfer my pics from the phone to the computer
There are 3 ways of doing this:
1. If you have internet service in your cell phone, send the picture to your e-mail address(ex. kakkaatt@yahoo.com) . Then go to your mail, open it, click save to (choose my pictures, computer or whichever file you want it) or click on save mail (save mail will keep your picture in your online save folder and you may access your picture form anywhere you can log on to your e-mails)
2. Go to a store that has photo services. Give them your phone xd card, they will download to a CD. Take the CD to your computer and download the pictures.
3. Connect your phone to the compuert (this step is more complicated) Use any photo-smart software to open your pictures.
Artgirl
Jul 08, 2008 | Motorola Cell Phones
Computers & Internet Logo
225 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
