Question about Dell Inspiron 1525 Laptop
Battery/charger problem? i have a charger and its pretty screwed up at the top and makes this poppy noise whenever you bend it now im pretty sure that its not under warranty anymore since my g.gma got it last mother day last year and its just now breaking and now the little light at my laptop is blinking 4 times orange somewhat fast and then is slow when it tuns blue then goes fast again and when my little battery icon at my system tray it was at 100% which i know is a lie because it was dead this morning and right when i turned it on it said 100% which is kinda odd if you ask me unless the charger magically started working and charged it up of which i doubt because it wouldnt turn on until i could get the charger to work again do i just need a new charger or a new battery or both because now im scared to move the charger in fear that it wont work again which is kinda inconvienent because its on the bed and its up against the place where your pillow usually is so my back now has no support and it sucks :(
  • 3 more comments
  • alekorm
    alekorm May 24, 2009
    ha now i dont know what oure asking umm....i have left the battery in i havent messed with that the only thing ive done is had to jiggle the top of the charger  to get a poppy noise but it wont work until i get the poppy noise which is weird but...oh well and its the side that plugs into the laptop that is screwed up
  • alekorm
    the side that goes into the laptop if it was the side that went into the wall that jiggles and popped then i would leave that alone and buy another one out of fear of it catching on fire
  • Frank Zhang
    Frank Zhang May 11, 2010
    yes, change adapter first, see how? then feedback your comment if still trouble please.
  • Frank Zhang
    I ask you:
    1) (to jiggle the top of the charger ) is this mean to jiggle ACadapter wire (but DC plug and socket are not shanke) or to jiggle DC jack then poppy noise appear?
  • Frank Zhang
    so you it can work noly with charger (AC adapter), do you turn on laptop without battery then reseat the battery in? tell me how?
    Sergeant:
  • 285 Answers
You can buy a new charger off of ebay, newegg, or somethimes dell. it will run about $20 .
Posted on May 24, 2009
Tip
How to replace the battery on the iPAQ 3800 and 3900 Series
Before starting the installation, please ... - Be careful when handling and <a href="http://laptopsbattery.co.uk/apple-ibook-g4-battery.htm">Apple ibook g4 battery</a>. - Care of common sense in handling the battery as to not bend (ie, bending), away from metal, away from extreme heat, etc. - Make sure all the data into iPaq have been saved.<br /> <img src="a_2000-ipaq-battery-t6-e0102.jpg" /> - Care of common sense in handling the Battery as not to bend (ie, bending), away from metal, away from extreme heat, etc.<br /> - Make sure that all data were saved in iPaq.<br /> - Read all instructions before your first attempt to replace the <a href="http://www.notebookbattery.ca/xps-m170.htm">Dell XPS M170 battery</a>. This will help you visualize the process before it even began.<br /> 1. Turn the power off, and make sure the reset button on the bottom of the unit is turned off to ensure the power is completely off.<br /> 2. Take pen from iPaq before continuing.<br /> 3. Using a Torx T6, get the four screws out of each corner. Make sure you do not lose the screws. Split the back cover of the main body by using your fingernail or other device such as a flat Phillips screwdriver. Make sure you<br />Do not scratch the surface when using a screwdriver.<br /> 4. Once the back cover is separated from the main body, open the back cover from the top. Do not leave everything the way that <a href="http://www.battery-mag.co.uk/hp-pavilion-dv2000.html">HP Pavilion DV2000 battery</a> is attached to the motherboard via a flexible connector PCB. Note: A hard reset slide the door lock button and stylus are not attached to the body, and therefore, they can be loose as the back cover is removed. They are easy to rear, but it is wise to take note of their location and position.<br /> 5. As you remove the back cover carefully, you will see a connector between <a href="http://www.battery-mag.co.uk/hp-compaq-nx7010.html">Compaq NX7010 battery</a> and the main board. Carefully remove the connector Battery. Please note that the Battery is glued to the back cover, and can be removed after<br />Unplug the connector on the main board.<br /> 6. Once you have the old Battery removed, align the new <a href="http://www.battery-mag.us/sony-vgp-bps9.htm">Sony vgp-bps9 battery</a> so that the edge of the Battery which is closest to the connector goes to the bottom (for example, the side is recorded on top).<br /> 7. Press firmly on the connector Battery. Make sure all corners are firmly inserted.<br /> 8. From the bottom, reinsert the backcover. Do not force the lid when closed. This means that the <a href="http://laptopsbattery.co.uk/apple-a1022.htm">Apple A1022 battery</a> is not properly installed on the back cover. Just realign the stack so it is secure.<br /> 9. Insert four screws back and turn the key to reset and power button, in that order, to ensure that the device operates normally.<br /> 10. You must fully charge the Battery, And let it charge for more than 30-60 minutes after the full load indicator is lit. This ensures that the <a href="http://laptopsbattery.co.uk/dell-latitude-d620-battery.htm">Dell latitude d620 battery</a> is fully
on Nov 10, 2010 | Computers & Internet
Have a hoverround mpv 4,do you charge with the controller on or off,when on i get a buzzing noise loud im thinking you charge when the controller is off need help thank you
Typically you will charge with the controller off, but it is not critical. The buzzing noise may be the fan on the charger, which is normal. Make sure the silver handle of the charger is fully inserted into the controller. If the light on the charger is on, you have kept the charger connected for 8-12 hours and still the batteries will not charge, there may be a problem with the batteries being bad and they need to be replaced.
Jan 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
I hear clicking noise when I make a right turn only
there is a TSB(technical service bulletin) available at your dealership for that. Im pretty sure thats the cv shafts making that noise. its very common.
Aug 19, 2009 | 2004 Infiniti G35 Sport Coupe
Frigidaire dryer makes a noise when it heats up
Maybe ya needs ta get in there and inspect the dryer.I am pretty sure you need to remove the top by getting the screws off the backside. Then you can remove the front and take a looksee
Remember the stack washer/dryer does not have the spring clips to pop the top (you have to remove screws from the back) Other than that basically all the innards are the same.
Jul 06, 2009 | Dryers
Won't start without charger on battery.
when you charge the battery make sure that its cable is is loosen from the motor coz it can damage your charging system. on your case you have damage it already that's your light dims whenever you rev the rpm up. so change your voltage regulator of your charging system, charge the battery and it is done easy.
Apr 25, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Ticking noise when trying to start
charge the battery if it take a charge and holds it make suer there are no interior lights left on,if not ,make sure the terminals are tight if all is good then replace the battery
Dec 10, 2008 | 1989 Pontiac Firebird
My magellan 1200 will not keep a charge when i plug it in...it will not turn on cause the battery is dead...when i plug in the charger to the unit it flashes a bright white light for like a fraction of a...
I agree. I suggest you should go to a technician and try a new battery. If the new battery does not work you should speak to your manufacturer.
Thanks for using FixYa!
Oct 17, 2008 | Magellan GPS
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
Dell Inspiron 1525 Laptop Logo
182 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
