Question about Panasonic Video Cameras
LCD monitor Flex Ribbon
I mean that is the problem that I have with my Camera.When I open the viewfinder in Full is totally white. When is opened partially its seen good. I want to know How to replace its and where to buy its. Thanks.
  • conn47 May 24, 2009
    The Camera is Panasonic mini camcorder model PVGS 19.
    Panasonic mini Camcorder model PVGS19. Thanks.
  • Panasonic Master
  • 13,433 Answers
Could you send me the brand and model and I'll look into the part. thanks
Posted on May 24, 2009
When i switch on my Lenovo g550 laptop i am getting white screen, if i connect same on other monitor i am getting display
you seem to have a problem with your lcd display, defective flex ribbon. if you can do open and check it out that would be better. this things really happens because we always need to open the laptop more than ones a day.
Jul 12, 2011 | Lenovo G550 Notebook
I do not see any image thru the viewfinder of the PV-GS250 Camcorder. I tried to move the viewfinder tube at different inclination and extended lengths, but no light or image appeared most of the time. ...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the vewfinder LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Apr 28, 2011 | Panasonic PV-GS250 Mini DV Digital...
White display LCD TV
The screen glowinh white mean it is not getting voltage to the LCD controller, the ribbon cable may have come lose. You need to open it up and look inside.
See some pictures here: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is spinboss@comcast.net and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
LCD screen continues rolling
There is connecting ribbon wire between LCD board and main camera board, this ribbon wire is cracked and needs to be replaced.
Dec 10, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Experts., pls help.! i beg you
check new flex ribbon cable if not solve the probe check new lcd if not working
get the phone to the nearest phone repairshop in ur area and tell him flash my phone
ok rate this post and give me ur feed back
Oct 28, 2008 | Nokia 3230
Powershot pro1 viewfinder show blank white
Hi
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Jul 15, 2008 | Canon PowerShot Pro1 Digital Camera
Monitor lcd
the flex wire of the lcd monitor is already cut...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Aug 16, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Lcd monitor and viewfinder not working when i try to record myself.
the flex wire of the lcd monitor is have a open line that why it is not functioning....there is also a switch to on the viewfinder connected to lcd....in some model even the lcd is damage you can still use the viewfinder...
Feb 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
Video Cameras Logo
67 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
