Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
The transmission won't pull on a hill. I would like to know the type of fluid that is used for a hydrastatic transmission.
What type of fluid is used for a peerless transmission for a yth180.
My yth 180 wouldn't pull up a hill either. I replaced the belt, engine pulley and even the transmission, Cost was $700.00, and none fixed the problem. I finally found that the clutch/brake peddle was sticking just enough to not allow the belt not to allow full engagement. When I reached down and gave it a good yank back toward me, I felt a click and the peddle released. Yep, that fixed it. Hope this helps you and saves you the big bucks!
Posted on Nov 05, 2012
  • 284 Answers
Bentonite grease should last for the life of the mower
check your belt tension?
Posted on May 25, 2009
My 2011 Nissan rogue will not climb hills and won't go above 80miles and hour even though the check engine light did not come on. Is it the transmission fluid or spark plugs?
It could definitely be the transmission fluid. Check the fluid level when the car is running and up to normal operating temp. You should have a mark on the dipstick saying "hot-full mark". That is exactly where your fluid level should be. Make sure you put in the correct fluid type, and that you do not overfill it. If it is not shifting like it should, then it could be time to change out the transmission filter. Not a difficult job, and a lot cheaper than a new tranny...
Aug 10, 2013 | Cars & Trucks
What fluid is used for the Hydrastatic transmission on a Yamaha YT3600
best advice is to contact the dealer and ask for the type of oil you are to use.
Apr 21, 2013 | Cars & Trucks
2003 ford explorer transmission won,t pull in any gear.
check make sure transmission fluid not too low or could have plugged transmission filter.or code scan for faulty transmission fluid pressure sensor or transmission range sensor bad or out of adjustment.transmission could have failed.garage has to run fluid pressure test see if transmission failed or you could have faulty shift solenoid..
Feb 26, 2013 | 2003 Ford Explorer Sport
Transmission problems for 98 dakota
Pull it out & have it rebuilt
Can pull the valve body & clean, if you like
doing that kind of work,doubt it will be the total
solution
Nov 25, 2012 | Cars & Trucks
Hydrastatic transmission not working right it is slow;
first check the belt tension then the fluid level if you can
Apr 10, 2012 | Garden
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Jul 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need to change manual transmission fluid
pull the lower plug from the transmission, it will be on the bottom or the side on the bottom. replace the plug after draining and remove the fill plug wich is about half way up the side of the transmission. use 75w 90 gear oil in the trans.
good luck
Aug 31, 2008 | 1999 Jeep Wrangler
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,200 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
