Question about Brother IntelliFAX 2800 Laser Fax
No manual i was given a entellifax 2800, but no manual...i want to set up name, telephone #s...etc...
    President:
  • 2,992 Answers
You can download the manual from Brother. Click here.
Posted on May 25, 2009
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
Hp slate 7 2800 8 gb silver at the screen for wifi asking for ssid don't what that mean haven't used it's been sitting in box given to me for a birthday present dont what to do
The SSID is the name that is broadcast by the wireless router to identify the wireless network(s). Most devices will perform a scan and provide a list of detected wifi networks. The names you see on the list are the SSIDs. It is possible for a wireless network to exist but not broadcast its SSID. In those cases you must manually enter the SSID in order for the device to scan for, locate, and attempt to connect to the wifi network.
Jan 17, 2015 | HP Slate 7 2800 8GB Tablet
Brother/model#2800 w/telephone/U56577J1/J614551
Go to the Brother page for the Intellifax 2800, where you can download the user manual and quick setup guide:
http://www.brother-usa.com/support/default.aspx?PGID=2&R3ModelID=PPF2800
Jun 01, 2010 | Brother IntelliFAX 2800 Laser Fax
How do I set it up as a fax along with my using my telephone on the same phone number
somewhere in the user settings it will have a tel/fax setting wich will allow you to hit "start" to manually receive a fax, also some phone companies can set you up with a distinctive ring for faxing, so you won't need to do a manual receive. when you pick up the phone in the tel/fax mode and hear the fax screech then hit the start button to begin receiving. hope this helps.
Jan 10, 2010 | Brother IntelliFAX 2800 Laser Fax
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Phone hookup
First only plug the line in the LINE socket otherwise it wont receive.
Manual receive will probably be the best as conflict may occur with the answering machine and the fax. You will either not receive faxes or messages. Its a bit of a pain as you will have to be home to receive faxes. eg pick up the handset and press start.
Its the easiest. Unless you want to fiddle with both machines settings to use the fax/telephone mode.
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Cannot connect using Appletalk protocol
Given that this issue is three years old, and AppleTalk protocol is no longer even supported, it probably should be laid to rest.
Oct 17, 2007 | HP Business InkJet 2800 Printer
Brother IntelliFAX 2800 Laser Fax Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
