Question about GE GSH22JFR Side by Side Refrigerator
GE Profile TFX25 just stopped working. Both freezer and refigerator section.
    Novelist:
  • 151 Answers
It's stopped completely First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
click this link directly to check out all the possibilities
http://www.applianceaid.com/refrigerator.html
thanks.please do rate the solution.keep updated.thank you for using fixya.
Posted on May 24, 2009
Not cooling
Sounds like a defective start relay, run capacitor overload and possibly a defective condenser fan may have started the problem. What is the correct model number found around the fresh food section door?
Sea Breeze
Mar 06, 2013 | GE Profile PDCS1NB Bottom Freezer...
Our GE Profile refrigerator with freezer on bottom is leaking water on the floor. There is ice build up on the back of the freezer compartment. Water stopped leaking when the filter was taken out. I...
GASKETS PLAY AN IMPORTANT PART IN THIS PROBLEM, DEPENDS ON HOW OLD YOUR APPLIANCE IS YOU COULD CHECK IF YOUR GASKETS ARE WORKING PROPERLY BY SETTING A SHEET OF PAPER BETWEEN THE GASKET AND FRAME AND PULLING THE PAPER OUT SHOULD HAVE A LITTLE RESISTANCE, IF PAPER SLIDES OUT WITH NO EFFORT IS A SIGN OF BAD GASKETS, THAT ALLOW MOISTURE TO GET IN AND CONDENSATE AT THE BOTTOM.
Dec 31, 2012 | GE Profile Stainless Bottom-Freezer...
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana bottommount refigerator--ABB1922FEW--- BUY 08-03-07 AMANA REFIGERATOR WARM---60+ DEGREES FREEZER ---YES---10 DEGREES FREDD- APHASIA--COMMUNICATION PROBLEMS--- NICKNAME: giesslerf PASSWORD: abd7f
Wow
Ican not understand what you need.
So I am guessing here
Ice has built up on the evaporator coil stopping air flow to the food section.
Try manually defrosting the fridge. If this works then the auto defrost cycle has failed and you will need to get a technician to help you
Mar 30, 2011 | Amana ABB1922FEW (186 cu ft) Bottom...
GE fridge PDS22MBSWW - relay clicks on and off
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
Sep 21, 2009 | GE Profile PDS22MBSWW
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Panel out
Replace the control bord if there is no function.
Jul 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22JFR Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
