Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Troubleshoot floormate spinscrub 800 floor cleaner
Re: floormate spinscrub 800 floor cleaner. the brushes do not reach the floor and is just spinning in air, how can i get them lower, thanks
  • mamadoon May 26, 2009
    i did download manual, it said nothing about what to do if brushes do not touch floor. the brushes do not come close to touching floor, like an inch above. there is no way the floor can be cleaned unless they sit directly on floor!!! help!!!
    Problem Solver:
  • 15 Answers
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
Posted on May 25, 2009
  • dhamester May 26, 2009
    I have found that the front nozlle may not be on correctly. First take off the nozzle and see if the head or brushes come closer to the floor.
    If this solves the problem, then you know it has something to do with having the nozlle on correctly.
    If this doesn not solve your problem, you'll need to take to an authorised repair station
I've had my floormate spin scrub for 3years now and all of a sudden the motor is make a loud squealing sound. What is wrong? Sounds like it's going to die. Is it? Can it be fixed?
take it to an appliance repair shop for a diagnosis and quote for repairs
could be a simple motor problem or could be more costly
any way the quote will show you to repair or replace with a new model
Nov 07, 2015 | Hoover H3044 FloorMate SpinScrub Wide-Path...
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
My hoover floormate hard floor cleaner is not sucking as stong as it use to. What can I do?
Sounds like the squeegee may be old and need to be replaced. Check that first. If you need a new one you can follow this link.
part number 93001095
http://www.usavacuum.com/h3040-h3044-h3045-s/213.htm
Feb 21, 2010 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
I used my Hoover FloorMate, SpinScrub Hard Floor Cleaner for the first time today. My intent was to clean the grout in my kitchen/family room floor. Since the water was dirty I know it cleaned the grout...
The Hoover model 800 has seperate brush assembly to do grout. The 500 model (yours) has only the one hight brushes so other means must be taken to do grout. I have a 500 and all tile floors and I'm bumbed too.
Kirk Thompson
San Juan,PR
Aug 14, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes won't spin
The power wire may be disconnected
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
Apr 21, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover h3030
In thi picture, did you replace #20? It is what drives the brushes.
Mar 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Spin bruches don't touch floor.
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Apr 28, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
393 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
