Question about Mitsubishi WS-65809 65" Rear Projection Television
How do I get 1080 with my tv?
How do I get 1080 HD
    Sergeant:
  • 285 Answers
You will need to connect an 1080p hd device to a 1080p tv via an HDMI cable.
Posted on May 24, 2009
  • Andrew Perrong May 24, 2009
    Assuming you have a 1080p HDTV, you will need to connect a cable or blu-ray box, or anything else that SUPPORTS 1080, via an HDMI cable.
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Is samsung series 45 led tv a hd tv?
There are different ratings for" HD Tvs. You will need to look at the pixel rating to detirmine exactly how defined it is. Most better models are 1080 pixels, but others at 740 are also rated in this catagory. Nowdays programming is sometimes 1080 friendly, but can still be broadcast at a lower rating. In such instances, the 1080 will not improve the picture quality....as the source quality is the max quality rating you can recieve. Good Luck.
Sep 01, 2014 | Televison & Video
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
I need the V-Chip code for an HD 1080 series TV.
delete characters by pressing cancel for each character
Dec 14, 2008 | Mitsubishi WS-55807 TV
Tv 1080 signal not responding to cable to get hd format
i have iptv an we cant get this tv set up on it can you help me please
Aug 11, 2008 | Soyo Onyx DYLTO32D 32 in. LCD HDTV
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
