Question about Refrigerators
Seal is broken water is leaking no light
  • nelliexbee May 24, 2009
    Where do I get a new seal to replace the old one which will fit correctly?
    Thank you. Very helpful!
    Novelist:
  • 151 Answers
The magnetic/rubber seal on the doors to both units If it's not in good shape, the fridge/freezer will admit outside (warm) air--.That warm, moist air enters the cabinet and cools. Cool air cannot contain as much moisture as warm air, so the excess humidity condenses out and collects in the bottom of the fridge. If the drains are blocked (or not) that moisture ends up on your floor as liquid water.and due to that same liquid water the circuit of the light bulb also gets short and the light do not come up. -------------------
You have to loosen or remove the plastic door liner to replace the seal.  there is an liquid glue like adhesive involved under the seal to stuck it.
--------------- to check the light switch click the link directly and get the instructions http://www.acmehowto.com/howto/appliance/refrigerator/check/interlock.htm
-------------------------- also click this link to check out how to replace the door seal which is leaking. http://monsterguide.net/how-to-repair-a-leaking-refrigerator
click the diagrams in the link to get the big /enlarged view. this will help you. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 24, 2009
  • spark9 May 24, 2009
    yes there is a online store
    www.repairclinic.com
    you can get the seal here.
    also for any other type of appliance part.keepthis link in your mind.it provides all the required part at your door step.just order the required.
    also this another link for more help
    click it directly
    http://www.appliancepartspros.com/_ge-re...
    also 1 more direct link
    www.partselect.com
    thanks.
How do i keep water out of my trunk
New trunk seal , that rubber thing around the edge of the opening !
Nov 01, 2015 | 1998 Buick Regal
Leaking anti freeze from water pump screw
Most water pumps have a weep hole that leaks when the pump seal is broken. Usually indicates the water pump needs replaced.
Mar 01, 2014 | Dodge Shadow Cars & Trucks
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
2001 toyota sienna water leak inside rear door seal
For water leaking inside the rear door panel, I'll suggest you check and replace the black rubber/foamy seal that is part of the high-mounted-rear light assembly.
It gets weak over time and soaks water, thereby allowing water seep into the booth lining and also into the underlay of the carpet.
If you have a cracked rear-light (the one attached to the boot hatch), you may also get a leak.
Change this rubber seal/ gasket. I used an old rubber carpet to make a gasket to fit the light assembly, and it stopped the leakage.
Hope this helps.
Feb 07, 2012 | 2001 Toyota Sienna
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
2005 excursion 4x4 v10 front axle outboard axle shaft to axle housing seal has broken but not leaking oil. This was noticed after dealership serviced needle bearing.
THE DRIVE SHAFT HAS TO BE REMOVE TO REPLACE THE PINION SEAL.DONT MATTER IF SEAL NOT LEAKING BUT SEAL NEED TO BE REPLACED TO KEEP OUT WATER DIRT OUT OF THE TRANSFER CASE TO KEEP FROM DAMAGING THE PINION BEARING.
May 02, 2011 | 2005 Ford Excursion
Single lever kitchen faucet,seal broken
To address the leaking problem fast, you may replace
the whole set.
1. Shut off the main water valve.
2. Take the leaking kitchen faucet off.
3. Replace the defective kitchen faucet.
4. After replacement, open the main water valve.
Of course, you could have repaired it. That is assuming that you could easily find the right seal.
Besides there is no guarantee that the location where
the seal will be placed is still not wornout.
Nov 29, 2009 | Plumbing
Have alarm code PO442 could you tell me what that is
evap code. this is the vent or tank pressure leaking, This light will come on if seal is broken in tank, gas cap seal is broken, vent line is broken or a cracked line in the vent system. a smoke test is best way to find this leak. No worries it isn't dangerous or make your vehicle run any different, just the light. good luck
Oct 03, 2009 | 2002 Kia Spectra
My washer is leaking water need help?
Hi, you will have to open machine,check, look for broken hoses, also check water pump, sometime when they go bad,they vent out water on floor, some models. also check where the main shaft, come through tub, there's a special water seal gasket(kit) that always with age start to leak, it's a commom problem with top loaders, if that the case, it's a big job, you will need a mechanic to replace seal. but check yourself could be broken hose or water pump. good luck.
Aug 04, 2009 | GE 3.2 Cu. Ft. 8-Cycle Super Capacity...
Water leaking onto floor when filling
OPEN WASHER panel and look inside while having the washer taking water , if water leaks under the tub , then its a broken seal , needs to be replaced , if not , check the around the DRAIN MOTOR PUMP , got 2 hoses connected to it , check if it broken or loose , hope this helps AJ
May 17, 2008 | Washing Machines
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
