Question about Garden
Oil leak at trans axle
I have a simplicity javelin 44 inch lawn mower with an oil leak at the left transaxle. i was wondering if anyone had ran in to this problem. Also can you get gaskets to repair or even add oil so i can use it for this season. If you can add oil what type would you use.
thanks
Keith
SOURCE: I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Posted on Apr 20, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 24 Answers
SOURCE: lawn mower simplicity
Check the air filter to see if it's cloged up with dirt and grass. You might need to rebuild your carb.
Posted on Aug 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 3 Answers
SOURCE: Transaxle appears not to engage
rider will not go forward or back
Posted on May 18, 2010
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
HOW BIG A JOB TO FIX A SNAPPER HYDROSTATIC LAWN TRACTOR. WHOSE RIGHT AXLE HAS "COME LOOSE?"
http://www.tractorbynet.com/forums/parts-repairs/164892-tufftorq-k46-repair-guide-pictures.html Most transaxles are Tufftorq. This great thread shows how to hand grind parts to get the mower going up hill strongly again, but it also shows how to take the thing apart and get it back together again.
Jul 29, 2014 | Omega Rear Drive Wheel Snapper Mowers
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
How to put oil in transaxle
You should have a plug in center of axle. Takes 14mm wrench.
Apr 12, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna YTH 150 lawn tractor and the left axle from my transaxle twisted off.
Typically the axle is part of the transmission. Unless you have knowledge or experience in disassembling them you might want to just find another transmission and install it.
Dec 12, 2011 | Husqvarna Garden
Oil leaking from under the exhaust mower has been
souds like the carb needs cleand out it has stuck open and let the gas run in to the moter
Nov 05, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Jul 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Jul 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
235 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
