Yellow ink contaminated
Yes, do you refil your own inks. Colour contamination occurs primarily when users overfill ink holes with any colour, then this colour runs into others and voila, a yukky mess. If cartridges are fairly new, heres the quick easy fix. Remove cartridges that are causing the problem, in your case all! Using a proper cleaning solution (you can get this free in refill kits or buy it sepeartely, i got mine from supermarket, works well) and cotton buds, thoroughly clean down where the cartridges sit. There will be both fresh ink and dried ink, so you will have to repeat over and over until all or most colour is gone from cotton buds. Now, let it dry and air, leaving printer cover open. You now have to bleed the black ink as it sounds like it is overfull. This can happen in refilled cartridges, but even store bought ones can have faults. Sit the black cartridge on wet paper towel, on a clean icecream lid or marg lid, even a plate will do, just one that you don't mind ink on by accident. Let it sit a minute or so, now lift it up, and wipe it gently with a wipe (i use unscented baby wipes-huggies, do not laugh, they work well!) press it firmly on a folded tissue, and it should leave a nice clean neat black vertical little line. If it doeas, place it back in its place in printer. Leave open for now. The colour cartridge should need cleaning too, by doing the same, each time you lift it off wet paper towel, wipe it clean, and press it on a tissue to see clean neat 3 colour line. If not, bleed again until it does. When it does place it back in printer and reset ink levels once cover is shut. Try printing now.
Clean the print heads with a cotton swab and alcohol and see if that solves the problem.
