Question about Panasonic Car Audio & Video
Could radio wiring be causing my truck instrument panel to fail?
Hi, I've recently encounted some issues with my 05 dodge ram truck. I'm not sure if this is radio related or not, but I've found evidence online that it could be. The problem was while driving, I suddenly lost my instrument panel guages. They stopped working, all lighting came on and a 'No Bus' error was dislayed, although the truck still ran fine. Long story short, ive done some research, and the error means the instrument cluster is not receiving messages from all PCM modules or something like that. I've read that the problem could be b/c there is a white/violet striped wire connecting all vehicle modules including cluster, radio, amp, ABS controller, A/C controller, and more. I recently swapped out my stock headunit for an aftermarket panasonic and wired it up myself using a wiring diagram I found online. One of the wires is a white/violet wire. The diagram did not list its use, and without it everything seemed to work fine so I left it disconnected. Everything worked fine for a few months until this happened yesterday. Does this wire need to be connected to the headunit via ACC, or ground or something?? Or can I just leave it as it is (plastic cap over cut end). Ive not found any info anywhere that mentions what should be done with this wire when installing an aftermarket unit. Any help is apprecated. Thanks -Keith
  • 3 Answers
That wire is probably data. What you may have to do is get a radio-relocation harness, contact your local car audio shop. The company is Metra out of Florida. You will need to get this harness, possible p/n 70-6512. That way your OE radio data bus remains connected. I have this harness in my inventory, but I am in Edmonton, Canada..
Posted on Aug 07, 2009
What would cause gauges to go on and off on1999 dodge ram 1500?
Ram trucks, Dodge Caravans, some of the Mitsubishi models, and Plymouths have this issue.
On the back of the instrument cluster where it plugs in has soldered contacts that weaken. This causes small cracks.
I have heard of the plug being loose on a few occasions but more often than not it's the contacts.It's not a difficult procedure to re-solder the cracks. But if you have a 99 Ram I'm sure your dash cover is no stranger to cracks.
Jun 01, 2015 | Dodge Cars & Trucks
My 2008 dodge ram 1500 will not start, but sometimes it does start, I 've had the starter checked, and my battery is good. So why won't my truck start?
Is there a red light on in the instrument cluster when the truck fails to start? If so, then the security system is setting a code that shuts down the starting system because it sees the truck being stolen. May want to check for security system trouble codes.
Feb 16, 2015 | 2008 Dodge Ram Pickup 1500
My 98 dodge ram 1500 (5.9L) recently had a voltage issue so i had the alt. rebuilt and since then i still have a voltage issue and also now have an idle issue. i've replace the plugs and wires and...
well, since you have already checked many options, one other thing that could cause a problem like that is the idle control valve,
pvc valve, throttle control sensor, and even the EGR valve, but a diagnostics check-up should tell you more efficiently what the problem is.
Dec 26, 2014 | Dodge Cars & Trucks
Instrument panel and radio lights randomly flicker
Sounds to me like a loose wiring connection behind the dash or possibly loose fuse connections
Aug 14, 2012 | 2004 Dodge Neon
I have a 2002 dodge 3500 quad cab dually 4x4 the interior lights and the radio quit heard a pop under dash no fuses are blowed
check all fuses.not just ones labeled radio or int lights thet might be fed from other fuses. check cig lighter fuse first
Apr 03, 2010 | 2002 Dodge Ram 3500 Truck
05 Dodge Ram will not start or turn over even when being jumped off. Just clicks. Last night when I tried to start it, ALL THE INTERIOR LIGHTS STARTED FLASHING AS WELL AS THE INSTRUMENT PANEL.
SOUND LIKE BATTERY IS DEAD.CHECK BATTERY VOLTAGE.A GOOD BATTERY VOLTAGE IS 12.5 VOLTS.IF LOWER REPLACE BATTERY.IF BATTERY IS GOOD CHECK BATTERY CABLES FOR TIGHTNESS AND CORROSSION.IF CABLES CHECK OUT GOOD.I AM LOOKING AT STARTER SOLENOID.REMOVE HAVE IT CHECKED.REMIND YOU TURN OFF RADIO BEFORE REMOVING CABLES SO YOU WONT LOSE CODE TO PLAY RADIO.IF IT TURN OUT THE BATTERY IS BAD. HAVE ALTERNATOR OUT PUT CHECK TO MAKE SURE ITS CHARGING THE BATTERY.
Oct 04, 2009 | 2005 Dodge Ram 1500
How do I do it to get to the radio?
Here is a link with a factory service manual showing step by step procedures with pictures and diagrams. 2006 Dodge Ram Service Manual
1. Disconnect and isolate the negative battery cable.
2. Using a trim stick C-4755 or equivalent (plastic trim removal tool from auto parts store),
disengage the retainer clips that secure the instrument panel
center bezel to the instrument panel.
3. Disconnect the wire harness connectors and
remove the center bezel from the vehicle.
Sep 26, 2009 | 2006 Dodge Ram 1500
Instrument panel on 05 dodge truck
Check to see that your battery is not bad. I recently had a similar issue and that was the fix.
Aug 07, 2009 | 2005 Dodge Ram 1500
Instrument panel guages quit. Getting 'No Bus' error in odometer.
That wire needs to be hooked to the factory radio , part of the PCI bus - serial data communication network . I know on GM vehicles if the radio isn't hooked to the bus the vehicle will not start an run . Don't know if Dodge vehicles are that complex . http://www.dodgeintrepid.net/31-car-audio-video/58412-why-pci-bus-connection-radio.html http://www.carsondemand.com/IDLdocuments/Learning%20Guide/4450-t9r0k5io6vxazm80x5ire9zj4.pdf
You mite call a aftermarket installer an ask or the dodge dealer
Feb 28, 2017 | 2005 Dodge Ram 1500
Car Audio & Video Logo
232 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
