I have an oil leak on my clothes washer.
The oil is yellow and light in viscocity. There is quite a bit of it on the floor. I t also appears to have been slung around inside, mostly on the front of the washer. I can't pinpoint the spot. Does anyone know where this oil is leaking from?
  • 26 Answers
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
Posted on May 25, 2009
My washing has yellow stains on white items especially around collars and cuffs Also bed linen
Since I do not know the style or type I may not answer your question but from experience it sounds like water is leaking into the transmission causing the oil to come past the seal into the wash causing the stains. Try these links and see if they help.
Appliance Repair Forums
Gearcase oil seal Whirlpool direct drive washer Clothes Washer Oil Leak Troubleshooting eHow Browse Path
Aug 03, 2016 | Washing Machines
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What oil viscocity for honda accord DX 1990 for cold weather ?
5W- 30 is the lowest you can go in winter time. I would use a high mileage formula since we're talking about a 1990 honda. It will help condition the seals in the motor from making any oil leaks worse.
Nov 16, 2009 | 1990 Honda Accord
I have water leaking out of the bottom of the drum. We came home one night and the floor and carpet were all wet after running a load of laundry. My husband and I,after cleaning up the mess, investigated...
Could be damage to drum ie hole in it .Pour some water in to it with a kettle or alike, this should tell you..Is it quite old or has damage happened due to coin,,Kind regards...
Sep 29, 2009 | Maytag PAV2300 Top Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Oil leaking underneath washer. Whirlpool
Your washer does not have a belt. Your gearcase is the trouble, part # 3360629. Hope this helps!
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil and black specks on floor underneath washer (middle)
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Jul 21, 2008 | GE WBSR3140DW Top Load Washer
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Feb 07, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
508 people viewed this question
Top Washing Machines Experts
