Question about Dell Inspiron 6400 Notebook
DVD player crazy
I was watching rented DVD's from the library and my DVD player finally started skipping during playing. Will I have to replace the player or is there a way to fix it? It's a DVD R/RW for a Dell Inspiron 6400. I've never had any problem with the computer before.
Thank you.
  • JDTec
    JDTec May 11, 2010
    Try the DVD's in other equipment first to verify that is is your drive or the DVD
    Master:
  • 461 Answers
Have you tried another disc to see if the problem is with the drive? If so, other than cleaning, the onlt solution is to replace the drive.
Posted on May 25, 2009
My sylvania sdvd6655-B skips and then stops playing. What can I do to fix it?
first time turning it on and all see is mod: not sopported
Mar 16, 2013 | Televison & Video
How do I fix a grainy/ patchy jumping/skipping dvd.
Hello, Bloody_dark -
Often those who rent DVDs or borrow them from the local public library mishandle them and do not know how to handle them properly.
From your question, it seems the DVDs are either scratched or dirty (possibly with food residue.)
This website gives step-by-step instructions on how to clean the readable side of a DVD:
https://www.wikihow.com/Clean-a-DVD
If, after cleaning, the DVD still is grainy, patchy, skipping, etc., it is probably scratched.
What I do when I have a rented or public library DVD which is scratched, I return it with a "sticky note" attached to the DVD box stating it is scratched and that I properly cleaned residue from the readable side of the disc, so that the rental business or the library staff will know that the DVD is damaged and can choose to replace it.
There are ways to remove scratches from DVDs, but I do not recommend anyone try those steps if they do not own the DVDs themselves.
Note: I am a librarian by profession and have seen firsthand how people mishandle DVDs. I'm from the 45-rpm and 33-rpm vinyl record generation. We learned how to properly handle those vinyl records so as not to scratch them. Bottom line: We were taught to only handle the vinyl records (and subsequent CDs and DVDs) by their outer edges. For CDs and DVDs, they can be held between the thumb and forefinger, along the inside and outside edges.
Jan 10, 2018 | Polaroid Televison & Video
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
Have the insignia DVD/VCR combo but after a few minutes or watching a DVD it starts to skip like four or five seconds of the movie then it starts to skip every second and then finally it freezes. Even if...
Hello
Its laser Picku Unit is faulty. Either it may be dirty, or its laser beam intensity has sent down. Just put a cleaning disc, and play it for atleast three times. If this helps you, you can understand that the lens of the laser assembly was dirty. If this also doesn't help you, repace the laser assembly with same type and number is the only remedy. OK.
Apr 30, 2011 | Insignia IS-DVD040924 DVD Player/VCR
Rented videos are freezing temporarily during playback
If the rented DVD is too scratched it will cause the DVD player to pause while it tries and find the next available playable area on the disc. This may cause the player to skip to another part of the movie. Try wiping the disc with a damp cloth from the centre towards the outer rim and dry the same way. Fingerprints ect. also cause problems. If the scratches are circular the player will have a hard time trying to play the disc. If the scratches are straight and small it shouldn't cause too much problems.
Mar 17, 2009 | Sharp DV-SR45U DVD Recorder
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
I have a Samsung BD-P1000 Blu-Ray Disc Player that will not play Blu-Ray discs rented from BlockBusters in Calgary, Alberta, Canada. To Date, of all my 100 regular DVD, and approximately 25 owned Blu-Ray...
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Nov 27, 2008 | Samsung Televison & Video
Go Video Model # VR3930
while playing a dvd the player will pause then skipping to a later part of the movie. It does it on any disc weather it is old or brand new. I need help. Thank you
May 08, 2008 | GoVideo Go Video DVD/VCR Combo
Movie skips and freezes during play
CD and dvd disc cleaners will not solve the problem, a deeper and delicate cleaning procedure by cleaning the lens manually with an cotton swab is needed...
Although the quality of newer discs is to be discussed.
Oct 09, 2006 | Toshiba SD-V392 DVD Player/VCR
All DVD`s installed in player skip .Also DVD`s that showed title donot now.
first thing i would do i clean the lens with 90% isoprople alcohol and a q-tip, if that doesn't work watch the laser eye again and the movement is the laser look like it tries to catch up???
i would put a dc volt meter on the motor and the motor should stay at lower voltage if it climbs then there is something with the rails or worm gear. let me know what you find out.
Aug 23, 2006 | Yamaha DVR-S120 DVD Player
Dell Inspiron 6400 Notebook Logo
106 people viewed this question
Alun Cox
