Question about LG CU500 Cellular Phone
Micro card doesn't work
Inserted sandisk micro and yet i still can't get phone to connect to my computer now phone wont acknowledge sd card frustration does not begin to explain this phone it really is crap
Go to Setings, Connectivity, USB connection mode, and select "mass storage". Windows should now show the media card when USB is connected.
Posted on Oct 22, 2007
SOURCE:
How do i format an sd card for my panasonic lumix dmc-tz40?
I have got a Panasonic DMC TZ70 I could not find out using the manual how to format the memory card. I discovered how .. set the mode dial at the top of the camera to MANUAL, then select menu then you can keep arrowing down until you find FORMAT, click yes and it's done.
Jul 22, 2014 | SanDisk 32gb X2 = 64gb Micro Sd Cell Phone...
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
My computer is not acknowledging the micro sd card in HTC phone
Check if your micro sd card is properly inserted in your htc phone.Go to the pc connections in your phone and set them to mass storage mode to access your sd card.
Mar 21, 2011 | Computers & Internet
Micro SD card wont work
Try Formating the 1gig chip in 'Fat' not Fat32, then put it back in phone,, should work then.
Also the phone aparently will only recocnize up to 2Gig (But U need a Firmware upgrade)
Hope That helps!
May 23, 2009 | Palm Treo 750 Smartphone
Where to I put the chip in my computer?
You may have to get a card reader that takes stuff off and puts stuff on the sd card that connects to the computer using a usb port because most computers do not have an area where you can insert the micro sd card.
Nov 15, 2008 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
Jun 05, 2008 | SanDisk Electronics - Others
Micro SD NOT WORKING (SONY ERICSSON W580i)
You need to buy a different kind. i just bought a 4G Microcenter brand and its doing the same thing.
i'd recommend a Sandisk M-2 microSD.
Apr 12, 2008 | Sony Ericsson W850i Cellular Phone
LG CU500 Cellular Phone Logo
67 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
