Question about Mitsubishi VS-70707 70" Rear Projection Television
Trying to find parts for Mitsubishi Big Screen Mdl# VS-7004R
I've had this TV for over 10 years and really like it. But I'm having a hard time finding part #334P19101 and the Tubing/Projection guns needed for the repair man to completely fix it.
Where can I find this parts, any help will be much appreciated.
Rosie Belton
  • Mitsubishi Master
  • 8,617 Answers
You should be able to locate the parts at the following link just leave them a email with the model number of your set and what your looking for. Just click on the contact us link in the lower left side of the page .
http://servicemanuals.vstore.ca/
Posted on May 24, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
1995 mitsubishi 60inch big screen
Probably a solder issue. try soldering around the flyback, line coilsand vertical and yoke plugs. You can get a service manual for 10.99 emailed to you at the following link. they also offer free support to help with the diagnosis of your Set.
Feb 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60607 TV bottom of the screen has dark areas
take the front bottom black panel off. it pulls off. unscrew the little panel in the middle. reach up and pull the wires down gently. unplug the 2 conectors gonig to the big metal frame holding the screen in. unscrew the 2-4 screws holding the big metal frame. pull up put screen on sheet to protect it. unscrew the screws holding both of the screens in. Pull apart and clean
Jan 23, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-70707 70" Rear Projection Television Logo
318 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
