Question about MandrakeSoft MandrakeMove 9.2 (Trial) (himm-001t)
Regarding default loacalhost login name and password
Hello sir,
              i have installed mandrakesoft  9.2 in my system and have not given any password or login name.and on starting it is asking for localhost login name and password.
so please tell me default values for above mentioned.
    Genius:
  • 1,601 Answers
 use the default Login name “admin”, and no password
Posted on Oct 22, 2007
Default login password
It would have been more comfortable, if you would have mention your router model name
so to give you the exact information about the password. Since to help you find default login and password for the router, please find the list of common routers from the link given below:
http://www.routerpasswords.com/
GuruAid.com
Mar 15, 2016 | Computers & Internet
I need to change the password for my router
http://kb.netgear.com/app/answers/detail/a_id/23439/~/finding-the-wireless-network-password-on-a-netgear-router-using-genie
Jan 07, 2015 | NetGear Computers & Internet
What is a username? Where does one get it?
A user name is one of the fields to be able to login to a protected system
To be very simple in answering i would s a user name is the ATM card that you own and is always static while the password is the pin that can change and at a given point of time there will be one password corrosponding to one username
The default username and password is mentioned in the manual that comes with your router
you can also specify what router do you have with model number and i would be able to find out the default username and password for you
Thanks and Regards,
I Am Araldite
Sep 02, 2011 | Computers & Internet
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
Hello sir /mam i have a problem is my daughter
If the password is stolen then please go ahead and login to www.yahoo.com
1. Enter your user name 2. Click on forgot password 3. Answer the secret question you had chosen earlier and then your password will be reset and you will be able to login again in your account
Mar 29, 2011 | Yahoo Mail
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Dgn2000 set up works fine through ethernet wireless no connection laptop has wireless which is swiched on router shows wireless active - what channel? does the router need to be switch to?
How can you configure wireless settings on the netgear router.
1. Open IE and type 192.168.0.1
2. Enter login and password ( By default user name "admin" and default password "password" in lower case.)
3. Once you login to netgear router page
4. On the left hand side at the top you have wireless setting click on that.
5. You will get following screen
6. Name SSID: (any thing) Make sure when ever you change any settings on the wireless screen always change Name of your network.
7. Mode you can select any one of the option
8. Under Wireless Access Point
a) Enable (This option is always check if you want to enable you wireless feature)
b) Allow (Broadcast of name (SSID) (This option is always check if you want to enable you wireless feature)
9) You can select any of the security option
10 Apply
Then you can see your network name on your computer which you have setup on the netgear router.
I believe no one face any problem after that but still i am here to assist you.
Thanks & Regards
Oct 27, 2009 | NetGear DGN2000-100NAS Router
D-Link Wireless router
Assuming you ahve windows XP or a lower version of windows installed
Click on start >> RUN >> type CMD
In the command prompt box type IPCONFIG. You'll get the ip address and default gateway. Note the default gateway. Open Internet Explorer and type the default gateway in the address bar and hit enter. you'll be prompted for a user name and password. Check router documentation for a default login name and password. Browse through the option to set the password. Would be hepful if you give the operating system and router model name.
Aug 31, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
304 people viewed this question
Top MandrakeSoft Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a MandrakeSoft Computer and Internet Expert? Answer questions, earn points and help others
