Question about Daewoo DV-6T955B DVD Player/VCR
DVD/VCR combo. DVD has no sound
My DVD/VCR combo is a few years old and suddenly I have no sound on my DVD. My VCR works completely fine. I have a perfect picture from my DVD but absolutely no sound...Any suggestions? The connection cables not been moved from where they've always been when it worked...
victorassimi
  • 11 Answers
SOURCE: Dawoo DVR07
you need specials cable for your conectiviti
Posted on Nov 15, 2007
  • 4234 Answers
SOURCE: Daewoo combo - DVD is fine, sound works but not picture appears
The video heads have been clogged. You can try a cleaning tape, but those often do not work. If that fails, you will need to have a professional clean the heads and verify the head alignment. This should not cost more than $50 or so.
Dan
Posted on Dec 10, 2008
SOURCE: Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Posted on Feb 22, 2009
SOURCE: Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Posted on May 11, 2009
  • 603 Answers
SOURCE: I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Posted on Dec 30, 2009
My toshiba dvd/vcr combo suddenly wont read dvd disc
Maybe the lasers ok but the disc motor is not spinning the disc.
Apr 28, 2014 | Televison & Video
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
The DVD player only has audio, no video
That may be a problem at the head of the video cable, try to replace it, and see if that solve your problem.
Dec 30, 2009 | Televison & Video
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
DVD Recorder VCR combo, VCR will stop after 23 sec of play or rec
necesito saber que tecla presiono para desactivar el modo progresivo scan
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Sylvania DVD/VCR combo
THERE ARE NO HEADS IN A DVD PLAYER! IT,S CALLED A
LASER. IF YOU TAKE THE UNIT APART DO NOT LOOK AT THE LASER IT WILL BLINED YOU BE CAREFULL WHEN YOU CLEAN IT. IFF WHEN YOU CLEAN IT IT STILL DON,T READ THE DVD,S IT MAY BE BAD. IF THATS THE CASE, IT,S TIME TO GET
ANOTHER DVD PLAYER. THE LASER COST TO MUCH TO REPLACE.
Jan 05, 2008 | GoVideo DVD-VCR Combo
Picture sticks, breaks up repeatedly
Change the location of the unit, this sounds like an overheating problem. It is too close to other units or is enclosed in a tight space. You may also try putting a small fan behind it to cool it down.
Sep 16, 2007 | Samsung DVD-V1000 DVD Player/VCR
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Daewoo DV-6T955B DVD Player/VCR Logo
122 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
