Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth handsfree problem
Hey i got a motorola v3i phone. ihave paired it with a nokia bluetooth headset. i can listen to every sound in it...except the songs. even i m getting the sound of the videos on the handsfree..but nt the audio songs. plz help me out!!
  • 432 Answers
Bluetooth uses a technique called spread-spectrum frequency hopping. It changes frequencies 1,600 times every second. A frequency of 2.45 gigahertz (actually between 2.402 GHz and 2.480 GHz, to be exact). For the bluetooth device to work at 100% it needs to be 100% compatiable. More than likely, if you change your earpiece device, you should be able to pickup your songs. If you go to the VerizonWireless website, they should have 100% compatiable devices.
Todays Tivia:
Why is it called Bluetooth?
Harald Bluetooth was king of Denmark in the late 900s. He managed to unite Denmark and part of Norway into a single kingdom then introduced Christianity into Denmark. He left a large monument, the Jelling rune stone, in memory of his parents. He was killed in 986 during a battle with his son, Svend Forkbeard. Choosing this name for the standard indicates how important companies from the Nordic region (nations including Denmark, Sweden, Norway and Finland) are to the communications industry, even if it says little about the way the technology works.
Posted on Oct 20, 2007
How do I connect my Motorola H720 Bluetooth headset to my PAnTECH P7040 cell phone?
Turn on Bluetooth on your pantech phone. Then H720 Bond Pair .
Motorola Support
Motorola Owners Forum
need help pairing my H70 Motorola Bluetooth with my Pantech P7040 cell...
Mar 08, 2015 | Motorola Mobility H720 H 720 Bluetooth...
How to connect bluetooth headset to my nokia c5-03 phone
Hi Madhav,
Thank you for your question at Fixya,
The solution to your problem is as follows :-
  • The blue tooth connection depends on the fact as to whether or not the bluetooth handsfree that you have is compatible with your phone or not , a good idea would be to check it before you buy one.
  • Now if you want to connect your bluetooth handsfree to your mobile , you need to first make sure that your phone's bluetooth connection has been switch on and then it's not hidden and it should be in shown to all mode as this is a nokia phone.
  • When you switch on the bluetooth connection in your phone , then you need to switch on your bluetooth handsfree and then keep it on.
  • Then again you need to go back in the bluetooth option and then select search for paired devices option or new paired device option , then the phone will search for available bluetooth connections.
  • If it detects your bluetooth , please accept that connection and then it will ask you for a pass code , which you have to enter as 0000 and then press ok.
  • That's it! you will have your phone successfully connected to your bluetooth handsfree.
Hope that helps ...:) In case you have any queries, feel free to contact me.
Sep 19, 2011 | Motorola Mobility Bluetooth Headset, Mini...
How to connect nokia 70 with motorola handsfree
is it motorola handsfree headset??
if so...
activate bluetoth of ur nokia cell,
activate the handsfree (pressing long the on off button,for connecting with new device)
1, it automaticaly send the connection request to nokia cell
2 if not, go to paired devices of ur nokia cell blutooth and search more devices.
select motorola handsfree,
enter passcode 0000
it will work.
May 01, 2009 | Motorola Mobility Bluetooth Hands-Free...
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 23, 2008 | Motorola Mobility Bluetooth Hands Free...
Lstening to music with a bluetooth headset
The bluetooth headset is not compatible with mp3's. try converting it to a different file and listening to see if it works
Apr 12, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Bluetooth wont connect
I cannot pair my bluetooth6133 coz I forgot the pascode
Sep 10, 2007 | GE Bluetooth In-ear Headset Wireless...
I loose BT connection after one song
Does the motorola headset make decending tones when it disconnects? If it does, you are listening to your music using the Headset bluetooth profile rather than the High quality audio one. You will need to change the way the device is paired to the phone. Try pairing it as bluetooth headphones or bluetooth high quality audio, rather than a bluetooth headset. Once you have done that, you can pair it as a bluetooth headset too, as the motorola headset connects to 2 bluetooth devices, or in this case, one device, with two profiles. To use the headset profile, press the left M symbol once, and the headset will play a sound to indicate connection as a headset. If you press it again, it will revert to High Quality Audio profile, and you can listen to your music, and even skip/pause it!
Apr 26, 2007 | Motorola Mobility HT820 Wireless / Cable...
Motorola Mobility RAZR V3i Cellular Phone Logo
62 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
