Question about Hayward Pool Products 55 Sq Ft Easy Clear Filter System w/ 1HP Pump
I have a brand new hayward filter for an in ground pool. The system uses D.E. The problem I'm having is after it's running for approx 30 minutes it looses all pressure. I've tried back washing it several time and it hasn't helped. Any suggestions/thoughts thanks, Mays
  • 59 Answers
You might change out the D.E. media. you can also run it without any media to see if it looses the pressure after 30 min. mor than likely it is just time to change.
Posted on May 25, 2009
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
I have a hayward s166t filter, guage reads 0 and sight glass water does not swirl when backwashed
Does it show pressure when in "Filter" mode?
If not, then your pump is either not primed, Impeller is plugged, or there is not enough water in the pool, you are sucking air.
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
Is the Hayward s210 pro series 21" top mount above
Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 28, 2011 | Hayward Pro Series 21" Above Ground Pool...
Can u hookup hayward Aquabug to intex above ground pool without disconnecting existing filter? Will both filters work at the same time? I would like to clean the top of the pool at the same time I clean...
You Aquabug pool cleaner works WITH your pools filter. You much connect the cleaner to your filter system and the filters suction is what powers the cleaner. Since they operate together, you should always run your filter while you are cleaning, but it will never operate in its normal capacity since you are using it for a different purpose. Here is a copy of the users manual if you have any questions about how the cleaner works.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Jul 03, 2010 | Hayward Aquabug Above Ground Pool Cleaner...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Filter problem with hayward pool system
You didn't say what your exact problem was so troubleshooting with you might be difficult. Below is a link to the owners manual for these pool filters. You should be able to get your filter running properly using this.
Jun 27, 2010 | Hayward Pro Series Side Mount Sand Filter...
Just opened pool for 3rd year, I cleaned the filter added new powder, motor very noisy and must bump the filter every 30 minutes
Filter needs to be disassembled, cleaned, acid washed and reassembled. Motor probably needs to have new bearings installed or be replaced
May 11, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward Swimpro Sand filter shuts off after approx 2 minutes
It sounds like the pump is either overheating or the thermal protection switch that senses the overheating situation is defective. If nothing else changed like running on an extension cord, etc, a small motor repair shop can get you back up and running fairly inexpensively.
May 23, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward Pool Products 55 Sq Ft Easy Clear Filter System w/ 1HP Pump Logo
153 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
