Question about LG Heating & Cooling
WATER COMING FROM VENT WHEN I SAT IT ON DRY
WHEN I TURN THE AIR CONDITINER ON WITH IN FIVE MIN WATER COME FROM THE VENT
    Guru:
  • 1,524 Answers
Check the unit with a level. It should be 1/4 bubble pitch towards the outside so condensate will properly drain.
Posted on May 24, 2009
    Problem Solver:
  • 11 Answers
Sounds like the drainage tube is stopped up or the canal. That should take care of your problem.
Posted on Jul 22, 2012
Location of air conditioning drain tube ? ( water condensate )
Passenger side under the van at the base of the engine bulkhead.
Aug 30, 2012 | 2000 Dodge Grand Caravan
I cleaned the vent but it still takes to long to dry
if it is heating well, then you have a ventilation problem,make sure lint trap is clean if so disconnect dryer vent hose from dryer turn dryer back on put your hand where vent is make sure good hot air is comming out if so dry a load of clothes without vent tube connected,they should dry in a normal amount of time ,if so then your dryer hose is either bent too much or collasped,if hose looks good then it will be vent leadinding outside you can take a leaf blower and put in vent and blow it out,your dryer either vents on the side of the house or the roof turn dryer on put your hand on exterior vent make sure air is coming through
Jan 23, 2011 | Dryers
Takes for ever to dry cloths
Remove the connecting vent from the rear of the dryer. Do a timed load a 50 minutes. If it is dry, clean out the connecting vent and the wall vent.
Jun 27, 2009 | GE Dryers
Gas go's on then shut off
Check the exhaust for good air flow.
Remove the rear exhaust vent and run the dryer.
If that corrects the problem repair the vent blockage.
If it does not correct the problem replace the gas valve coils.
Mar 12, 2009 | Whirlpool Dryers
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
Not geting hot enough
The most common thing to cause this is a blocked vent. Start the dryer and go out to where the vent comes out of the house and see how hard it blows. If you feel little air out the vent, you will need to unhook the dryer from the vent and see how hard it blows there. If it is blowing good there you need to have the vent pipe cleaned. If dryer isn't blowing hard out the back, please reply back with the model number so I can give more detailed directions on checking the blower wheel and ducts.
Oct 11, 2007 | Kenmore 74602 Gas Dryer
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Heating & Cooling Logo
124 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
