Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Intermittent shut down
I have a Dell Dimension 5150 desktop PC which has developed an intermittent shut down problem the system will boot normally but after an indeterminate period it shuts down and restarts automatically. It may do this several times and then eventually it goes into a continuous reboot without ever attaining a complete restart. If I switch it off for a while I can eventually get the PC to reboot properly once more only for the problem to manifest itself once more.
  • Håkan Sterner May 11, 2010
    One easy thing you could try is to have a look inside, inspecting all
    cooling sinks and fans so they are clean and operational. If there is
    dust you must not use a vacuum cleaner due to risk of generating static
    electricity and damage, use compressed air instead.
  • Dick
    Dick May 11, 2010
    It is impossible to give you a definite answer to your problem without thoroughly testing your system. It could be caused by many things ranging from a virus to a hardware failure. If you cannot do any testing yourself, take the computer to a shop.
  • 3 Answers
My Dell 5150 Dimension P4 3.0 Ghz was doing the exact same thing. The problem is very common with this model. No PC clinic I took to can solve my problem. They said it's MB, it is not! The problem is due to insufficient cooling from the factory 120MM fan which draws little air. Here is how I fix it. Remove the plastic shroud that holds the heatsink by losening the 2 screws and unplug the fan wire from the MB. It should come off easily unless your heat sink compound has hardened. Thoroughly clean the Al heatsink/fan with a long bristals brush.( Optional: If you want, remove heatsink compound from cpu and HS and apply a thin even layer of Artic silver with your index finger covered with siran wrap). Buy an 80mm quiet fan (Sunnon or any good brand)with a large 4 pin connector and get 4X 1.5" 1/8' self tapping screws. Mount the fan so the bottom just clears the HS on the MB. Direction of air flow is away from HS. Look for the arrow on the fan If the screws won't tap into the al HS, squeeze the al plates closer. Don't over tighten the screws, it's al, it is soft. Install back hs/FAN , tighten the two green screws and clean inside of PC with brush on the outside of your house. Plug in the fans power. Fire it up leave in on for a week, your HS should be ice cold. Another solution is buy a newer Pentium dua1 core that uses 65W instead of the 95W chip from Dell. A good one is E5200 at C$80. In this case ,you dont't need the extra fan. To upgrade your PC with a non Dell MB is possible. Get a Zotac ITX MB 170MMX170MM . Some grinding maybe needed. One good one is Zotac NF610I-D-E MINI-ITX LGA775 GeForce 7050 DDR2 1PCI-E1 2SATA2 RAID LAN VGA Motherboard at C$65
Posted on Jun 05, 2009
    Sergeant:
    Champion:
  • 212 Answers
That has to do with windows programs. Try doing a system back up if that doesn't work wipe the hard drive and put windows back on it. I have the same system and that has happened to Me. That is what I did. Now it works fine.
Posted on May 24, 2009
I'm looking for advice on how to reboot a dell dimension 5150
You can reboot by Operating system , Click start>Restart
OR
you can press power button for few seconds, it will power off, & then you can press power button.It will start booting up...
Thanks for choosing Fixya
Mar 16, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 5150/E510 ethernet controller
heres the link to the 5150/e510 drivers page. just select your operating systems from the drop down box and the category being network. be sure to select the intel driver , not the utility or update.
Jan 03, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Haii.. i got a dell dimension 5150 pc desktop the problems is always when i boot time ,its shows a blue screen thats tells the system have to shutdown and check ur hard disk,i have changed the hard disk...
Boot machine then press F8 till u see Advanced Boot options, then go into Safe Mode with Networking and follow instructions on the link below to turn off Auto Reboot on Blue Screen.
http://www.tunexp.com/tips/maintain_your_computer/disabling_blue_screen_of_death_auto-reboot/
Then, get BlueScreenViewer application to Debug what is causing it.
http://www.nirsoft.net/utils/blue_screen_view.html
Do a Find on the site for the word 'Download'
Sep 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 5150 computer wont boot up -flashing amber light
While the system begins booting --before the xp logo shows, if it gets that far for you, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The OS will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to format the drive and reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 22, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Amber Flashing Power button on bootup
i would change the battery first of all. this is the reason for losing date and time
Jul 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
363 people viewed this question
Alun Cox
