Question about Garden
Featherlite fuel lines
Wich fuel line is supposed to have the filter attatched, the line on the left or right when viewed from the back of trimmer? the fuel lines were dried out and fell apart so I replaced with tubing but not sure how it was hooked up.
  • 284 Answers
You have a primer bulb correct?
when you push it see which part squirts the fuel OUT that is your return line the other would be the suction or filter side.
Posted on May 25, 2009
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 | Garden
Gas problem
Check gas cap to make sure breather holes aren't plugged. Check screen inside tank where shut-off valve is to make sure it isn't clogged.
Apr 18, 2010 | Poulan Featherlite Gas Blower, with Low...
Is there a secret to replacing gas lines on a trimmer? my new lines seem too big and don't want to fit into the hole
Yes, the lines should be larger than the hole or they will leak. The last thing you should do is drill the hole bigger!
First cut the end of the new line on an angle and push it throught he hole as far as you can. Then with a long set of hemostats reach in through the fill hole and grab the line and pull it up through the fill hole. Cut the line straight then and attatch the fuel filter and push it back into the tank. Next, pull the excess line back out of the tank until the filter lays nice and flat on the bottom of the tank and you are ready to cut your new line to length and attatch to the carb or primer bulb.
Hint: always purchase more fuel line than you think you will need. That will give you excess to play with when cutting your angles and pulling it up through the fill hole.
Dec 28, 2009 | Craftsman 25cc Gas Line Trimmer
Is the filter attached to one of the fuel lines in the tank of a featherlite fl 20 suppose to be able to move around in the bottom of the tank???
Yes,it should be. I have bought used ones before with the filter missing on the end of the fuel line. You can get a lot of **** stuck in the carb without it,the jets on a trimmer carb are so small,it doesnt take much.
Aug 17, 2009 | Garden
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Featherlite FL 20 fuel line assembly
1 from filter in tank to carby 2 out of carby to primer 3 from primer back to tank
Jul 06, 2009 | Garden
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
