Question about HP Pavilion dv6000z Notebook
My Battery is **** in my laptop HP DV6000 series
The slide switch will not move and the battery will not come out. Help!
  • 1,889 Answers
Push in hard on the battery then slide the button
Posted on May 24, 2009
My hp laptop dv6305us screen is blank power light is on but screen is totally blank.
The DV6000 series of notebooks are known to have problematic motherboards. Try the below options:
1) Hold the power button down for 5 second and the machine should shutdown. Then power on again.
or
2) Flip the laptop over and switch the "lock" switch to "unlock". Then flip the release button to remove the battery for a few seconds. Put the battery back in and try to power the laptop on.
or
3) Power on the notebook like normal. Watch the Hard Drive activity light (the one that looks like 3 stacked plates), if the screen is blank and the activity light is solid or flashing, you know that the LCD screen is bad and needs to be replaced. If that light is not flashing then the problem is your motherboard and it needs to be replaced. Call HP and ask them if your model was part of a DV6000 series recall, if so your repair costs might be covered.
Regards,
Jacob
Mar 05, 2011 | HP Pavilion dv6305us Notebook
I have two HP dv6000 laptops and can't unlock the battery from either one. The tab that you slide to unlock won't move.
Hello.
I have a few suggestions:
Press down on the battery and then slide the tab.
Try compressed air in and around the tab.
Be gentle and use a flat screwdriver to move the tab - careful not to break the tab or damage your laptop.
Hope these suggestions help.
Dec 26, 2009 | HP iPAQ hw6515 Pocket PC
My hp laptop won't start.
This is more than likely whats going on
HP website says what to look for
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
Good luck..
Aug 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Laptop Battery Problem
I had a similar problems and I had my batter replace by Hp free of charge. Most like your batter could be damage internally or it could be a motherboard problem.
I suggest you visit this HP link http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Jul 03, 2009 | HP Pavilion dv6000z Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
HP DV6000 Battery problem
Bring it back to the repair shop if it has still repair warranty. They should take care of it.
Dec 04, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
