Question about Philips 23PF5320 23 in. HD-Ready LCD Television
How to associate the av sound with the HD video out
I have no sound when connecting sony ps3 to Philips 23" LCD TV 23PF532 on the HD source using an HDMI to DMI cable and have found that when i change the source to AV/SVHS, the sound from the ps3 can be heard. Is there some way that i could associate the sound from the av with the HD source?
  • 476 Answers
Re: how to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Posted on Feb 09, 2008
0 characters
3 Points
HOW to view sky tv on ..
Connect skybox using scartlead, or if you have HD use HDMI lead connection..
Select connection by using the AV (alternate video input) on your remote control--this will switch from freeview to sky.
Happy viewing.
Aug 10, 2014 | Hitachi L32H01 32 in. HD-Ready LCD TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Flat Panel Televisions
    Trying to find a port for sound input on Philips DVI LCD TV.
    If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
    Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
    Ps3 gets sound but no picture when using hdmi cord
    you need an optical lead for the sound and hdmi for the picture
    Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
    No sound on the hd setting on my lcd phillips hd tv
    look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
    Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
    PS3 to sony bravia
    If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
    Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
    No or bad video
    The picture is really dark but u can see movement on the screen, right ? Sounds like you might have a bad inverter on you LCD, a bulb burnt out or a faulty power supply. Problems to an lcd are not very many. More than likely bad lcd on each side of LCD panel there is a board that has a cable running from the power supply to it. Probably 8 to 14 pin connecter. If u have a meter check the DC voltage were the pin connector plugs in. 2 to 6 pins in a row should read 12 to 24 ( all should read the same) the other pins on the connecter will be a ground. Oh make sure the Inverter that u are checking is the Master and not the Slave.
    May 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
    Ps3 HD
    Hey i had the same problem i had to go out and buy a sound system for the ps3 that had the AV connections for sound and i plugged the av cableprovided in and now i get sound. Its a pain to have to switch on a seperate device for sound but its the only way.
    Dec 07, 2007 | Philips 23PF4321 23 in. HD-Ready LCD...
    Philips 23PF5320 23 in. HD-Ready LCD Television Logo
    301 people viewed this question
    Top Philips Flat Panel Televisions Experts
    Are you a Philips Flat Panel Television Expert? Answer questions, earn points and help others
